Horn button problems
Old Nov 11, 2012 | 08:36 PM
77Quadravan's Avatar
77Quadravan
Hello everyone,
I posted this in the F-Series section because the steering wheel is the same and there are a lot more of you than there are us van guys here.
On my 77, some kid decided to pull my steering wheel apart and mess up the horn buttons. there are two pieces of rubber that are supposed to keep the metal contacts separated until you press down on the horn button. Well he yanked those right off and there's no way in hell I can get them back on without ruining the metal contacts. Any suggestions would be greatly appreciated. Also how in the world do you get the horn button itself back on the steering wheel?
Thanks, Chris.
Old Nov 12, 2012 | 04:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 77Quadravan
Hello everyone,
Welcome to FTE
What are you calling a "horn button" .. the vinyl horn pad?
1974/77 F100/350's, Bronco's and 1975/77 Econolines came with a black 2 spoke steering wheel (D4TZ-3600-A) that uses a vinyl horn pad.
1975/77 F100/350's & Econolines with Speed Control came with a different 2 spoke black steering wheel (D5TZ-3600-A) that has the Speed Control switches located in the vinyl horn bar.
The only round horn button you'll find is the one on the optional 3 spoke "sport" steering wheel introduced in 1978.
Old Nov 12, 2012 | 11:17 AM
77Quadravan
Welcome to FTE
Yes It is the vinyl horn pad. But the problem is what's behind the horn pad.
Old Nov 12, 2012 | 06:21 PM
NumberDummy
Vinyl horn pad assy attaches to steering wheel with two screws. Look at the backside of the wheel for holes.
Vinyl cover part of plastic body that contains horn switch. Two wires feed from body, pass thru steering wheel.
D3TZ-13A805-A .. Horn Pad-Black Camera Case Finish / D3TZ-13A805-B .. Walnut Wood Grained Finish
1973/77 F100/350 (1975/77 without Speed Control) / 1974/77 Bronco / 1975/77 Econoline (without Speed Control).
D5TZ-13A805-B .. Horn Pad ~ Use with Speed Control.
1975/77 F100/350 & Econoline.
All 3 reproduced by Dennis Carpenter located in Concord NC (800-476-9653).
Old Nov 12, 2012 | 08:05 PM
77Quadravan
Just what i need. Thank you.
js74f250
May 12, 2016 04:31 PM
bratko
Jun 9, 2015 08:38 AM
connork
Jan 16, 2014 05:12 PM
InfidelReaper
May 10, 2013 03:36 AM
ffillah
Sep 5, 2012 01:18 PM
