what does this mean?
Old Nov 11, 2012 | 03:37 PM
79beaterbilt's Avatar
79beaterbilt
i noticed something with my 79 f350 today
After driving around in the fields a bit only goin through 1st or second since it has no brakes the clutch pedal was just below the brake pedal when warmed up. If i pull on pedal it pops up to the stopper under the dash. Is this a sign of the clutch goin out? If it makes a difference this truck hasen't been used in 4 years and i just got it running.
Old Nov 11, 2012 | 03:57 PM
I-6 Power's Avatar
I-6 Power
I am experiencing the same problem, only mine does it all the time; the clutch pedal does not return all the way up to the stopper under the dash. Any thoughts?
Old Nov 11, 2012 | 04:47 PM
79beaterbilt
the issue im having is more this way- before i could've sworn it was just above brake pedal and then after some driving around and truck warmed up it was below brake pedal
Old Nov 11, 2012 | 04:53 PM
kobaltblue's Avatar
kobaltblue
Return spring is missing.
Old Nov 11, 2012 | 05:05 PM
fordman75's Avatar
fordman75
Or the pedal bushings are worn allowing the pedal to bind.
Old Nov 11, 2012 | 07:24 PM
gnwalker's Avatar
gnwalker
Or the threaded rod from the clutch fork to the linkage needs adjusted
Old Nov 12, 2012 | 05:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Clutch pedal coil return spring located above clutch pedal, attaches to bracket the brake/clutch pedals suspend from.
Over time it loses the ability to return the pedal all the way, so you have to pull the pedal up by hand (or foot).
Old Nov 13, 2012 | 12:08 PM
I-6 Power's Avatar
I-6 Power
So, how difficult is this to replace? Any thoughts or tips before I jump in to replace it?
Old Nov 13, 2012 | 06:01 PM
79beaterbilt
Old Nov 13, 2012 | 06:07 PM
NumberDummy
I've never replaced it, but I've seen it replaced several times in dealership shops, it's not fun. 1977/79: There are two different types, what size is the engine?
IMO, replace with a new spring, user may not be any better than what you have now, could be worse.
Old Nov 13, 2012 | 06:59 PM
79beaterbilt
the issue is the clutch lost height.... im not worried about the stopper....
Old Nov 14, 2012 | 07:30 AM
I-6 Power's Avatar
I-6 Power
It's a 1979 F100 300 I-6 with a 3 speed on the column. Would you happen to know the procedure in which to replace it? I was hoping my dad and I could do it ourselves. Seeing as though not many repair shops in my area work on trucks of this age, I'm very limited on options to fix it.
Old Nov 14, 2012 | 08:02 AM
NumberDummy
Nope.
D7TZ-7534-B .. Clutch Pedal Return Spring / 7 1/2 coils, 3 3/8" long / 1977/79 300/302/351M / Obsolete
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
HASELDEN BROTHERS in Hemingway SC has ONE = 843-558-2134.
PARTS INTERNATIONAL in Farmers Branch TX has THREE = 888-727-0418.
Old Nov 18, 2012 | 02:10 PM
I-6 Power's Avatar
I-6 Power
Thank you for your help, NumberDummy. I'll see what I can do...
Old Nov 18, 2012 | 05:37 PM
wyckedcombo17's Avatar
wyckedcombo17
Try adjusting the threaded rod on the equalizer bar. I've been where you are, and after going through 3 springs the adjustment rod finally made the difference
