Clutch issues
Old Nov 13, 2012 | 06:21 PM
  #31
DanielT28's Avatar
DanielT28
Haha. Well I'm gonna get another master cylinder. Install it in a bit. Keep you guys updated. I honestly think the clutch is fine. But we'll see
Old Nov 13, 2012 | 09:39 PM
  #32
DanielT28's Avatar
DanielT28
No luck. The clutch fork seems to be moving less now. Thos is rediculous.
Old Nov 13, 2012 | 09:41 PM
  #33
madpogue's Avatar
madpogue
How far is the pushrod moving?
Did the starter lockout situation change at all with the new master?
Old Nov 13, 2012 | 11:52 PM
  #34
DanielT28's Avatar
DanielT28
Nope the clutch pedal goes all the way to the floor. And the slave cylinder is only moving 1/4 ". I'm so angry.
Old Nov 14, 2012 | 12:01 AM
  #35
madpogue's Avatar
madpogue
That could well be a bleeding issue (and I mean the hydraulics ).
What's going on with the switch, and being able to start it? Did that improve any? Did the new master come with its own pushrod and/or switch?
Old Nov 14, 2012 | 09:38 AM
  #36
DanielT28's Avatar
DanielT28
I can pull the switch by hand and it'll start. . The bushings on the pedal seem to be snug. . I need a vacuum bleeder but there's no fitting or anything to put it on. All there is is a set screw type bleeder
Old Nov 14, 2012 | 11:04 AM
  #37
DanielT28's Avatar
DanielT28
I'm beginning to thinkbsonething went wrong in the pressure plate :/. I just can't seem to get the clutch to dis engage. Guess its time for a new clutch
Old Nov 14, 2012 | 11:08 AM
  #38
DanielT28's Avatar
DanielT28
The new master comes with a rod and you remove the switch from the old onto the new rod. The spring seems fine & everything on the switch. I'm just puzzled because it seems the clutch pedal is going all the way to the floor just fine. But hardly any resistance. Therefore the safety start switch wont engage. Also after I pull the switch by hand and start it the gears just grind. .. So I'm thinking something may not be right with the travel of the master cylinder. But there's no way to ajust the rod length on these and it'd suck to spend $700 on a new clutch. Install it and come to find that it's not even the problem
Old Nov 14, 2012 | 02:39 PM
  #39
richdawg's Avatar
richdawg
Have you replaced the DMF with SMF ?
Old Nov 14, 2012 | 02:48 PM
  #40
superduty4x4's Avatar
superduty4x4
My guess is you aren't getting enough throw from the master cylinder to engage the switch, or disengage the clutch. That's either because you still have air in the system, you need to fine-tune the clutch linkage by re-clocking the swing arm on the end of the clutch pedal shaft, or both. Bleeding the clutch hydraulics on these trucks is notoriously hard, which is why most guys will opt to buy a complete pre-bled assembly rather than replace one component or the other.
Old Nov 14, 2012 | 03:16 PM
  #41
DanielT28's Avatar
DanielT28
What's a SMf o DMf ?
Old Nov 14, 2012 | 03:18 PM
  #42
DanielT28's Avatar
DanielT28
If your referring to dual mass flywheel or single. I haven't touched any of that. I've had this truck 3 months. The guy said it had a new clutch "installed by the ford dealer " just before I bought it. I just don't wanna spend that much $ unless its an absolute necessity. ( I'm hoping its just the hydraulics. )
Old Nov 14, 2012 | 03:19 PM
  #43
DanielT28's Avatar
DanielT28
How do you re clock the clutch pedal? By cutting welding etc ?
Old Nov 14, 2012 | 03:26 PM
  #44
strokin'_tatsch's Avatar
strokin'_tatsch
I'm still going to say that your hydraulics are not bled completely. We are on the internet, but it seems to me that your giving up bleeding the hydraulics. You may need to get a friend to give you a hand in order to get all the air out. Get a friend to work the clutch pedal while you open/close the bleeder screw. Just do it the same way as you would bleed brakes. Pedal on the floor, open the bleeder, close the bleeder, release the pedal. Sometimes it may even be necessary to build a little pressure by pumping the pedal a few times, then hold it on the floor and open the bleeder. Anyways. Try to bleed it again. Keep working it until you get pressure. If it absolutely won't build pressure, I would take back both the master and slave cylinder and go buy a pre-bled unit. If a pre-bled unit solves the problem, you may not have been bleeding the old ones right.
Old Nov 14, 2012 | 03:39 PM
  #45
DanielT28's Avatar
DanielT28
Okay. Well I'm getting frustrated. But not wanting to give up. I love my damn truck. It's pissing me off though. I feel like back handing it. Haha. But I'll try it more after work. Pedal to the floor. Open. Close. Pump. Check fluid. Add fluid. Pedal to floor. Open. Close. Etc.
