change Radio
Old Nov 11, 2012 | 08:23 AM
Commander666's Avatar
Commander666
change Radio
Hi, Folks!!
What to change the old Ford Radio with new cd player. Did someone know how to put the wires on?? Here a picture of my cables and connectors
the left one is totally unknown...he has 8 pins: Speaker???
Where i´ll find a wire diagramm`?
thanks a lot
Old Nov 11, 2012 | 08:16 PM
Franklin2's Avatar
Franklin2
What are you working on? What year and model? There are many Ford wiring schemes for the radios.
Old Nov 12, 2012 | 02:20 AM
joshofalltrades's Avatar
joshofalltrades
for everything going into the radio, we usually have to run a new wire from the battery for the power lead. it should be fused the same as the radio itself is, usually 10 amps.
from there, use a test light to identify the switched hot wire and a good ground wire, or run a new ground wire if you aren't completely sure.
from there, identify your speaker wires, they're usually an obvious pair going to any given speaker, such as grey and grey with black stripe, or purple and purple with black stripe, etc.
most of the times when i install an aftermarket stereo, many of the factory wires are left disconnected, so don't be afraid of that. just get a definate identity of every wire, and wire it to the diagram that came with the radio, usually red to switched hot, yellow to battery hot, black to ground, blue to power antenna or CD changer (left unplugged on models without these options), and speaker wires are the rest of it.
Old Nov 12, 2012 | 09:12 AM
Commander666
@Franklin2
Sorry, i´ve totally forget it: 94er E-150 Chateau
@joshofalltrades
Thanks a lot. Any idea where in the www i´ll find a wire diagram for my Econoline??
Old Nov 12, 2012 | 11:35 AM
Franklin2's Avatar
Franklin2
See if this diagram makes any sense. It came up in a google search.
http://www.justanswer.com/uploads/Wr...eo_94_F150.gif
Old Nov 12, 2012 | 02:37 PM
joshofalltrades
i've never looked for the diagram on this, i just take a little $2 test light and set about identifying wires. one wire in the radio group will have power only when the key is on, thats the one you need for the radio's switched 12v wire, power from the battery, and ground should both be run new
speaker wiring is all you have left to worry about, and you get to figure out the speaker wires for yourself, as they may be aftermarket, or you might want to add speakers to go with your new stereo.
these really aren't too hard to do, just make proper connections using butt connectors and a crimping tool. don't just twist the wires and tape them, that method is a fire hazard
Old Nov 12, 2012 | 03:27 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and the best is to solder them!
Old Nov 13, 2012 | 07:08 AM
Commander666
Thank you very much. All of you...nice hints. I´ll try it
Old Nov 29, 2012 | 09:42 PM
V10man's Avatar
V10man
You should be able to buy a pig tail to connect the aftermarket radio to the pigtail and plug that into the stock conectors. Walmart may even have it. It will tell you which wire is which.
Old Nov 29, 2012 | 10:29 PM
joshofalltrades
v10man, you're trying to take all the fun out of it
TheCoach
Jan 11, 2015 12:31 PM
mdmn_mk2
May 8, 2013 11:51 PM
kedwinh
Aug 5, 2011 08:59 PM
NavyMIDN08
Mar 5, 2010 05:29 PM
red rock 78
Feb 27, 2009 10:13 AM
