horsepower estimates
Old Nov 9, 2012 | 01:22 AM
jerry73's Avatar
jerry73
Hi I have a 390 wit a 1974 block and heads,stock butterfly pistons,bored .60 over,mild hydraulic rv cam,long tube headers,edelbrock performer intake manifold,and factory adjustable rockers....does anyone know roughly how much horsepower I will be pushing?
Old Nov 9, 2012 | 09:06 AM
73FOMO's Avatar
73FOMO
260-275 would be my quick estimate based on dyno simulatino software. Need more specifics on carb size, heads, and cam profile.
Old Nov 9, 2012 | 10:03 AM
jerry73's Avatar
jerry73
Didn't the 390 come out with 275-300 depending on the year. The heads unfortunately do have the little smog ports on them but they are running into some 2" headers. I don't know the cam specs and valves havnt even been adjusted yet
Old Nov 9, 2012 | 10:26 AM
73FOMO's Avatar
73FOMO
Yeah....265 hp an up I believe. Headers definitely help, but I need more specific's, valve size, carb size, cam specs and I can plug them in and fine tune the numbers. Also knowing the exact compression ratio helps. A good intake and good headers definitely help but are bottle necked and don't realize full gains with stock smog heads.
Old Nov 9, 2012 | 10:34 AM
85e150's Avatar
85e150
Car 390s
9.5 CR, 2bbl = 265 gross HP in late '60s to end of the run.
10, 10.5 4bbl = 300, 315, 320, 330 and 375(!!) over the years.
FE Series Engine Specification Chart
Pickup motors, especially near the darkest days (1974 would be a dark day) with compression in the 8s or lower, lazy cams, 2bbl carbs, did not make the power the car motors did. Add to that the change to net HP ratings, and they look pretty weak. (which they were, for the size and amount of gas they used....) But they pulled a low revs and lasted a long time. So you've corrected a couple flaws, but still have low compression. Thus the wags (multiple, as you have 2 threads going on this....) at the "low" numbers.
https://www.ford-trucks.com/forums/1...stimation.html
Old Nov 9, 2012 | 10:38 AM
73FOMO's Avatar
73FOMO
Originally Posted by 85e150six4mtod
Car 390s
Ditto that....I used 8.5 - 1 for comp ratio and 2 barrel carb in my simulation. And small valves on the heads...not sure of the exact valve size on the heads he listed.
Old Nov 9, 2012 | 10:53 AM
gpence's Avatar
gpence
So what's your dyno thingy say for a 10.5/1, 0.40 over, 282/292 cam (only numbers I remember off the top of my head) holly street avenger 770 cfm, heddman long tubes & gasket matched intake.
Old Nov 9, 2012 | 11:33 AM
jerry73's Avatar
jerry73
It's a car motor out of a cougar...it's 4bbl but I still can say for the valve and cam specs,I could try to look but I don't have the spec papers at my house
Old Nov 9, 2012 | 03:01 PM
73FOMO's Avatar
73FOMO
Got anymore info on the heads or valve sizes? Plugging in what you said approximate as I don't have ALL of the cam timing and lift numbers....325 hp @ 4500 and 400 torq @ 3000
Old Nov 9, 2012 | 04:06 PM
gpence's Avatar
gpence
Basic 70's crap PI heads with nothing more than hardened seats & valve job on them. I'm working on some after market aluminum heads as my next upgrade. Idk what my timing is set at but I can look at the lift and such when I go out to the shop.
capone550
Nov 19, 2012 09:10 AM
53Fordman
Nov 24, 2008 12:20 AM
Fordever2
Mar 29, 2005 03:28 PM
fordeverpower
Sep 17, 2003 09:58 PM
79_ford_400_guy
Feb 12, 2002 03:47 PM
