6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
New Tuner cat/dpf
Old Dec 7, 2012 | 12:09 AM
  #31
redz284u's Avatar
redz284u
Does anybody know if our computers keep track of how many times u flash them? I live in California and thinking of a egr Dpf delete with tune. But if the computer keeps track of flashes, I know they will fail u at the inspection.
Old Dec 7, 2012 | 07:15 AM
  #32
RM2738's Avatar
RM2738
From what I know... No. Here's info direct from a Ford Service Manager.
This is one of those "Good to know" pieces of info. At least it is for me and I thought it was worth sharing.
Ford has many dtc's that can not be pulled with the tunner. Have had mini maxx say no codes and pulled a long list of codes using the ford IDS. Reprogramming also leaves a string of "U" codes that are module to module comunication codes that can not be pulled with the mini maxx. Any time DTC's are cleared a P1000 will be there immediatly even if the H&S product isn't pulling it and remain there untill the PCM has ran long enough to clear it.
U0073 Control Module Communication Bus A Off
U0101 Lost Communication With Transmission Control Module (TCM)
U0121 Lost Communication With The Anti-lock Brake System (ABS) Control Module
U0137 Lost Communication With Trailer Brake Control (TBC) Module
U0151 Lost Communication With Restraints Control Module (RCM)
U0155 Lost Communication With Instrument Panel Cluster (IC) Control Module
These codes in general are ignored for general diagnotics unless it seems relevent to concern present. Multiple U codes generally happen when programing the PCM because it looses communication with the other modules during programing. But other things can cause these codes like low voltage where non essential modules shut down in low voltage conditions. Or high voltage where modules will shut down to protect it in high voltage situations. So a dead battery or a jump start could set U codes but would also be ignored if you are also seeing low or high voltage codes. Now if you are seeing only U codes with no other codes that would logically cause a U code then you start suspecting something else like a module reprogram from the likes of a the programmers that we are running.
Many codes are proprietory to ford software, meaning that only ford software can see these codes. Also the ford software can pull codes from specific modules not just the PCM and TCM like the H&S products. What it comes down to is unless you are going to put a vehicle back to stock and run it a 100+ miles, a dealer can tell if they look hard enough.
Pretty reliable info from a Ford employee.
Old Dec 7, 2012 | 05:28 PM
  #33
caprang's Avatar
caprang
Very good info!! That wouldnt be a concern at a state inspection since i doubt they have ford on site checking the codes. i have heard if the dealer suspects a tuner for such reasons like all the U codes, that they can retrieve a regen history. I don't know how long the memory is but the statement made to me was "if we only saw 1 regen in the last 1,000 miles it would tell us what we need to know". I'm not claiming this as fact, just what a reliable tech said to me. I had made the comment to him about programming a truck to stock and driving it a few days for a tuner to be undetectable.
Old Dec 7, 2012 | 08:08 PM
  #34
StanleyZ's Avatar
StanleyZ
That subject has been discussed on here a lot with no clear answer. It's mostly second or third hand info about how the dealer can find the codes. Seems like one of the teckkies on here said a regen or two would cover the tracks. I just figured the warranty was over when I did it. just not worth the stress of worring about it. Besides, we are on the road a lot far from home with the 5th wheel and if it fails on the road I wouldn't have a DPF with me to put on. Based on the posts on this forum most of the really bad things that happen to these trucks aren't gonna let you reinstall and drive through a couple regens anyway. The trucks going to the dealer on a tow truck hook.
Old Jan 5, 2013 | 03:37 PM
  #35
Delta2142's Avatar
Delta2142
Originally Posted by xpl0sive
i did my delete on Friday, it took me about 2 hrs... i took it down in once piece cat+DPF together. Didn't have to screw around with the DPF to cat bolts. For me what took the longest was getting the DPF out of the muffler pipe. The thing was rusted in there pretty good. But once I had it out, it was smooth sailing from there. that assembly is one heavy SOB.
I've noticed my MPG has already gotten better... went from about 20L/100KM to 15L/100KM which is the same as going from 12MPG to 16MPG
By chance do you want to sell your DPF?
Thanks Darrell
Old Jan 5, 2013 | 05:12 PM
  #36
redz284u's Avatar
redz284u
Ill let u know once I find a suitable delete and program. I'm still trying to get my truck smoged and registered.
Smokiesman
Apr 25, 2013 01:44 PM
9.ford.5
Canadian National Chapter
Dec 12, 2008 09:57 PM
MuddyAxles
New York Chapter
Sep 7, 2007 05:40 AM
trucklady
Car/truck Buying Advice
Sep 23, 2004 12:11 AM
