part number question
Old Nov 8, 2012 | 10:46 AM
whackit's Avatar
whackit
i'm trying to track down a small seal. i couldn't find the number in the master parts catalog.
it is for a 65 f100. at the drive end of the prop shaft (the short shaft on a two piece driveshaft) there is a universal joint with a splined slip joint which goes to the main driveshaft. on the splined end there is a metal washer and then a cork seal which fits over the splines. i'm looking for the cork seal.
thanks!
Old Nov 8, 2012 | 12:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
That's not surprising, considering it's a real b!tch to find.
It is for a 65 F100. at the drive end of the prop shaft (the short shaft on a two piece driveshaft) there is a universal joint with a splined slip joint which goes to the main driveshaft. on the splined end there is a metal washer and then a cork seal which fits over the splines. i'm looking for the cork seal.
First you have to look up the driveshaft (basic number 4602) to get the slip yoke number code (42). Then you take this code to the slip yoke charts (buried in the catalog-took me a 1/2 hour to find the damn thing).
Then read thru the chart until you find the slip yoke part number that 42 represents (C5TZ-4841-F). The seal is listed next to the part number.
O1Y-7097 .. Cork Seal / Obsolete / Cork shrinks with age, soak the puppy in hot water, then let it dry before installing.
ANTIQUE AUTO SUPPLY in Arlington TX has 1 = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has 16 = 800-543-4959.
There is no pic for an F100, I used the F250 pic (Illustration section 46, Page 4). And the thing is, I was pretty sure I knew the part number up front, but wanted to verify it.
Total time spent: 45 minutes, pushing my time spent on FTE today to 11 straight hours. Peepers look like two burnt holes in a blanket.
I owned a similar 1965 F100 for 44 years, so here's some more info. The 3 U-joints used w/a two piece driveshaft have 2 cups that are 1310's, 2 cups that are 1330's:
C5TZ-4635-F .. U-joint / Dana/Spicer part number: 210392-X = Comes in handy at autoparts stores.
302flareside1992
Offroad & 4x4
May 29, 2014 12:52 PM
66_in_ky
Jul 20, 2009 01:14 PM
eaglecomm
Jan 19, 2008 09:56 AM
cordespc
Jun 23, 2007 04:26 PM
58shortbed
Sep 12, 2004 05:08 PM
