Replacement panels for 8' stepside??
Old May 21, 2003 | 01:25 PM
Jokerz Wild's Avatar
Jokerz Wild
Does anyone know where to look??? Every place I try is either 8' fleetside, or 6' stepside. It seems nobody does 8'stepsides.
My bed has got some bad cancer in spots. I've gotta get it fixed sometime soon. The right fender is a little flappy...the wall has rusted along the lower back side of the fender flair.
Does anyone know if someone makes a complete 8' stepside bed in FG?? I know it'd be expensive but.......
Old May 21, 2003 | 01:52 PM
hippie667's Avatar
hippie667
You may try Bronco Graveyard or www.motorhaven.com.
They seem to have lot of parts. Hope this helps.
Ronnie
Old May 21, 2003 | 02:22 PM
mudmnky's Avatar
mudmnky
I have a 6' stepside and have done some extensive searching. Pro's Pick will make 6' sides witout the inner well for the tune of $320 a side. the 8' might be a little longer. I personally went down to the local metal fabricator and got two sides made out of 14 gauge steel for $100. I'm making the stake pockets out of box tubing and the bed lip roll out of .095 steel tubing. Right now I have less than $200 in it, and its going to be stronger than the factory.
Old May 21, 2003 | 02:35 PM
Jokerz Wild
mudmnky-Do you have any blueprints or plans that you'd be willing to share? How about pics?? What will the weight difference be from stock??? Sounds real interesting.
Thanks for the quick responses!!
Old May 21, 2003 | 02:53 PM
mudmnky's Avatar
mudmnky
I havn't got any definate numbers yet. I'm kind of building at as I go. I 'll try to help you out any way I can.
bigfoot5
Sep 18, 2013 09:53 PM
mwc2010
Aug 8, 2011 09:28 PM
78f250lj
Jan 28, 2010 12:32 PM
nwoparamedics
28
Nov 13, 2004 07:47 AM
idealtrucks
Aug 9, 2002 11:26 AM
