Electric Window won't go up
Old Aug 17, 2002 | 08:18 PM
92lightning's Avatar
92lightning
Post Electric Window won't go up
My 92 XLT's drivers window no longer go's up.I found this out the other morning during a thunder storm.It acts like the gears striped.If I grab the glass with pliers I can run it up. Thanks SAV
Old Aug 18, 2002 | 05:25 AM
MustangGT221's Avatar
MustangGT221
OK, so I assume you're asking how to fix it? Take the screws out of the door panel. The panel has plastic push pins holding it on, so you have to carefully pull the panel off. Once you have it off, you'll have to gently remove the plastic barrier if it's still on, and have a look at the system. You should lubricate the arm and other moving parts with some good spray lubricant. Once inside, you can have a look at what the problem could be.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 18, 2002 | 05:28 AM
Supercab's Avatar
Supercab
As long as the motor will run-(you are probably getting a click-click-click)as it trys to go up, if this is the case you just need whats called a "gear kit" they run about $14.00 at chain parts stores on the "Help" rack, you need to remove the motor itself, then remove the back plate on it & you will find inside a real mess of broken plastic and grease, just scrape it all out well, then put in your new gear, pack with grease re-install the plate & re-install motor back into the door.
Old Aug 18, 2002 | 06:50 PM
92lightning
Thanks,I'll stop Monday and pick a kit up.It's got to beat a plyers on the glass. Thanks again.SAV
Old Aug 19, 2002 | 12:04 AM
pross's Avatar
pross
ditto---exact same prob. w/my '91. I had to drill out the rivets and replace w/ SHORT 1/4-20 bolts w/self locking nuts. Be SURE if you use bolts instead of rivets, that the bolts don't get in the way of the arm. Check travel up and down before putting the panel back on. p.s. I could not physically get to one of the bottom ones. So I just left it off. (3 inplace of 4 will work)........
Old Aug 28, 2002 | 09:01 PM
92lightning
Old Sep 3, 2002 | 04:27 PM
3greenfords's Avatar
3greenfords
I replaced mine this weekend. Very straight forward once I got the stainless rivets drilled out. Once inside the gears were fine. I replaced the teflon ***** that absorb the torque from the motor and put the whole thing back in the door. Total time two hours. BTW I got the teflon ***** free from Advance Auto parts. He pulled them from a defective gear and gave them to me gratis.
bjarnold1
1978 - 1996 Big Bronco
Jan 4, 2014 12:48 PM
92 Black Nite
Jul 5, 2011 11:58 PM
countrysF250
Feb 8, 2011 08:08 PM
RJH123
Oct 27, 2009 09:32 AM
kfelczak92broncoxlt
Jul 8, 2007 07:34 AM
