slow speedo
Old Nov 7, 2012 | 09:01 AM
reddnekk's Avatar
reddnekk
slow speedo
My 66 F100 has a 68 390, 67 Borg Warner 4 speed. Speedo is 25 mph slow. I can only go 1 tooth smaller on the gear. Anything else to make it accurate?
Old Nov 7, 2012 | 09:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
What is the number of teeth that the DRIVEN gear (end of cable) has now?
Is the gear nylon, cast iron or have a steel shaft with a fiber gear riveted to it?
Old Nov 7, 2012 | 04:03 PM
reddnekk's Avatar
reddnekk
Currently the gear has 17 teeth. It is nylon with a slide on keeper. Looks like 16 tooth is as small as they go.
Old Nov 7, 2012 | 05:05 PM
NumberDummy
16T DRIVEN gear is it, but the DRIVE gear on the output shaft should also be taken into consideration. What is the rear axle ratio?
Old Nov 8, 2012 | 04:42 AM
reddnekk's Avatar
reddnekk
slow speedo
Just happen to have rear end & tranny numbers: REAR END= 3.25 6EB31:3 WDM-H (1968). TRANS= C8AR7006-D. TAIL SHAFT= C7OR(0R?)-7A040-A (1967).
Old Nov 8, 2012 | 08:01 AM
NumberDummy
Just happen to have rear end & tranny numbers: REAR END = 3.25 WDM-H 6EB (1968 cast 2nd week (B) of May (E), 1966 (6)) / TRANS CASE = C8AR-7006-D / TAIL SHAFT= C7OR-7A040-A (cast 1967).
My 1966 F100 has a 68 390, 1967 Borg Warner 4 speed.
Case marked C8AR-7006-D = Ford part number: C4AZ-7005-F .. Transmission Case ~ Ford 4 Speed Manual "top loader" / Applications: 1964/71 Ford/Merc Passenger Cars.
"Tail shaft" marked: C7OR-7A040-A = Ford part number: C6OZ-7A039-C .. Extension Housing ~ Ford 4 Speed Manual "top loader" / Applications: Misc 1966/69 Ford/Merc Passenger Cars w/289/302/351W/390.
Sorry, there's nothing I can do. Ford 4 speeds were not installed in trucks, so there's no application charts for speedo gears listed in Ford truck parts catalogs.
Old Nov 8, 2012 | 11:38 AM
reddnekk's Avatar
reddnekk
slow speedo
Thank You for trying! I know you will be of great help in the future. Thanks again.
Old Nov 8, 2012 | 02:40 PM
SuperSabre's Avatar
SuperSabre
Take your truck to a speedometer repair shop who has knowledge of classic vehicles. You may be able to come up with a speedo DRIVE gear, the one on the trans output shaft, that will make up the difference. Failing that, there are gearing correction boxes that can get you closer. These do not come cheap, however. If all else fails, buy a portable GPS nav system which will not only tell you your speed, more accurately than your speedometer, but other useful info as well. Good luck!
Old Nov 8, 2012 | 07:11 PM
66f-100's Avatar
66f-100
Assuming that your speedometer is good condition, there are 4 variables that come into play.
1) Drive gear on output shaft
2) driven gear on speedometer cable
3) rear end ratio
4) tire diameter
You didn't mention what size tires you have. Oversize tires will make the speedometer read lower than actual speed. Verify the rear end ratio with a helper by rolling the truck slowly on level ground and count the number of revolutions of the drive shaft for one revolution of the wheel. The tag may say 3.25:1 but it could have been replaced with something else in the past 46 years. The drive gear on a toploader is usually 6 or 7 teeth (dependent on original rear end ratio of the vehicle it came out of). The tailshaft needs to come off to change the drive gear. Here is a reference formula that may help you:
Speedometer Calibration Program - Method 1
Old Nov 9, 2012 | 01:28 AM
NumberDummy
1968 Galaxie 390 4 S/T / 3.25-1 / 8.15-15 tires / 6T DRIVE gear / 17T DRIVEN gear.
kevinfelix
22
Aug 1, 2011 03:06 PM
PetesPonies
Jun 2, 2010 11:04 PM
christians63
Feb 15, 2010 04:09 PM
pinguin
Nov 21, 2003 10:16 PM
Southern Fried
Feb 7, 2002 03:35 PM
