it sounds so easy.....
i had the 3rd best gto at the nationals NOT the best....but what do they know!!!
There is NOTHING from an original MII that you can use on your truck! The OEM IFS is too narrow, was originally built for and was barely strong enough for a Pinto and came with TINY brakes more suited to a go-kart. In other words it's total cr**!
The aftermarket MII TYPE suspensions use no OEM Ford MII parts with the possible exception of the spindles and/or ball joints. (oops! there goes your no other parts but Ford! emphasis...)
If you meant you are going to look for a previously owned MII type kit, make sure it's one designed for your truck, there are a lot of them out there for other makes and models, as well as Chinese clones of dubious quality and replacement parts interchangability.
I find it "curious" that someone with two GM product show winners is so set against anything but Ford parts?
<a href="http://s103.beta.photobucket.com/user/rjinator/library/F100%20BUILD" target="_blank"><img src="http://i103.photobucket.com/albums/m156/rjinator/F100%20BUILD/2012-02-21210836.jpg" border="0" alt="Uploaded from the Photobucket Android App"/></a>
Welcome Aboard! We were up in Syracuse last summer - beautiful
countryside.
Some thoughts below:
o Rear Suspension - An easy one weekend job to replace the stock rear end with the granny gearing. Most folks go with a 9 inch Ford F100 rear axle from a '57-'72 or an 8.8 inch from Ford Explorers. You looked like you were interested in going the Donor route for something - replacing the rear end is pretty straight forward. Our's is from an '01 Explorer & came with disc brakes, emergency brake, & 3.73 gears - $125 from salvage yard.
o Front Suspension is a lot more complicated - The most successful Salvage front end is from the Jaguar discussed above. Otherwise it's around $2K for a Mustang II Style kit from Heidt's, No Limit, TCI, etc.
We went the Mustang II coilover route - took months to do cutting into the frame, welding, steering, brakes..
Good luck over there & have fun!
Ben in Austin
1950 F1 (351W/AOD)
it sat am and i'm thinking....were you here in the syracuse area to attend the syracuse nationals? i was there and you must have walked right by me!! i/m the guy parked in the middle of the walk way where i shuddent be, the blue 65 gto hard top with the loud mouth,obnoxious owner, don't you remember??? (so, you think you guys were wacky!!) anyway, its a really good show. and if you come back this way give me a jingle and we'll get together. i cud show you around and take you bass fishing, its my other vise
q in syracuse
Somewhere up above you mentioned that you were thinking of putting a Lincoln seat into your truck. I've got a 1950 - our space limitations are pretty challenging - no more than 51 inches wide so we stuck with a small pickup seat from an S-10. Others have used Dakotas, Rangers, etc.
Your truck is a bit wider so you have more choices. Here is the
article posted on the forum regarding available wisdom on seats that fit..
Just for your easy bedtime reading - from the starter link up at the top of the forum... Everything you ever wanted to know about seats...
Ben in Austin
1950 F1 (351W/AOD)
"Here are some measurements that you might want to consider when looking for a new seat.
· Inside cab width from door panel to door panel (where the seat bottom is the widest)
o 1948-1952 F-1 = 53.5 inches
o 1953-1956 F-100 = 58 inches
· Distance between the door handle tips
o 1949 F-1 = 51.5 inches
· Distance between the fat part of the door handles
o 1949 F-1 = 45-5/8 inches
· Distance across the cab at the rear door post
o 1949 F-1 = 57 inches
· Distance from door panel to door panel
o 1957-1960 F-100 = 62 inches
· Distance from door handle to door handle
o 1957-1960 F-100 = 56 inches
· Stock bench seat width
o 1960 F-100 = 59 inches
There seems to be an issue (particularly found by older members of the forum) with the space between the steering wheel and the seat shrinking over time, resulting in limited intestinal accommodation. Fortunately the newer seats use a different type of spring so they tend to be thinner in the back. This provides more room in that area. This is something to think about before you buy a big, fat seat out of a Cadillac or Lincoln or some other land yacht. With a newer seat, you will usually pick up storage space under the seat bottom as well.
The following suggestions are based upon input from this forum. There is also an article in the August 2004 issue of Classic Truck that deals with this subject and contains many pictures of the suggested alternative seats. Note that we are not spending time discussing bucket seats. Once you ditch the console, you can pretty much fit any bucket into any truck, although generally you’ll end up with a built in headrest sticking up in your back window.
1948-1952 Trucks – Seat Width No More Than 52 Inches
· 2000 Ford Escort buckets
· Mid/late 1980s to 1996 Ford Ranger or Broncos
o 60/40 bench or buckets
o Perfect fit
o Used by many
o Bench is 51” wide at it’s widest point
o Back folds forward
o No headrests to poke up in the back window
o 2-door donors fold, 4-door donors don’t
o Very popular with members of the forum
· 1989 through mid 1990s Ford Explorer
o Buckets or 60/40 bench
· Middle or rear seats out of a 1996 Dodge Caravan
· 1996 and newer Chevy Astro Van
· 1996 and newer full sized GM van middle or rear seats
· 1995 and newer Toyota Tacoma
· 1994 and newer Chevy S-10/Sonoma
1953-1960 Trucks – Seat Width No More Than 58 Inches
· 2001 F-150
NOTE: There are several different styles of bench seats used in the late 1980s through late 1990s GM trucks – quasi-buckets, 60/40s and full benches. They all tend to have thin backs which helps to increase leg space where needed. Some have built in arms rests and a level of seat bottom sculpturing to them, some don’t. These seats are also well liked by a number of the members of this forum.
· 1988-1998 GM truck seats
o Excellent looking brackets
o Easy to adapt
o Headrests tend to be removable
· 1988-1994 Chevy Silverado bench
o No headrest
o Fold down arm rest
o Very stylish
· 1997 and newer F-150 bench
o Has a built in headrest
o Brackets are a bit of a challenge
· Late 1990s Chevy Suburban
· 1987 Chevy pickup bench
· The 2000 and newer Suburban
o 60/40 bench
o Removable headrests
o Not the most stylish thing
o Brackets are clunky looking
The 1999 and newer GM Silverado 40/20/40 “bench” is an interesting possibility. It’s 60 inches wide, but it’s really more like two buckets with a “jump seat” between. You could easily omit the middle section and put in a narrower console or nothing. They do have built shoulder belts, saving you the issue of mounting the shoulder restraint to the wall between the rear window and the doors. You might fit this whole set up into a 1953-1960 F-100. The 1994 through 2001 Dodge truck also has a similar set up, though less stylish than the GM version. It will have the same pluses and minuses.
Another issue to consider is that you need to build some sort of bracket to mount your new seat(s) to your truck. If you’re using the 1988-1998 GM seats, it’s pretty straightforward. Just look at the stock GM mounting brackets and it’s a no brainer. However, if you’re using Ford seats or buckets, this can get a little tricky. For a few good pictures of the brackets one member made to install a later model seat check out this thread. https://www.ford-trucks.com/forums/sh...d.php?t=114729 The work was done by KAI - our German buddy. He was putting a 1980 F-350 seat in a 1954 F-100. His brackets deal quite nicely with the weird bend/angle in the front of the stock Ford brackets. They are wonderful in their simplicity and could easily be modified to compensate for a shorter driver.
For an excellent example of brackets fabricated to hold the 1996-2000 Ranger 60/40 bench/bucket, check out those made by Scott123 (Scott Jones). He has provided pictures and plans, so you could make a copy of the “Scott123 Super-Duper seat frame 2000” if you wish.
Check out their galleries for the pictures/plans referred. "<!-- / message -->
<!-- sig -->__________________
Fomoko1..Morris
<!-- / message -->
just went out and cut some 4" square 1/4" plates off the front of my frame, just p.o.i....they must have used my f-100 for a snowplow at some point.
q in syracuse
today's a good day. i'm taking my m-8 to a local racing/rod motor builder for evaluation of my 4.6 and tranny AND going to a town 40 mi away to buy at least 2 more front fenders and a clean hood. the one i have has louvers all over it and it warped a little when sandblasted. and, drew, if yer watching, yesterday i had to clean the bottom of my bass boat and the motor. holy crap!!! working on my f-100 is much more satisfying. anyway i'll post tomorrow am
q in 'cuse
some bad news
i took a 100 mile ride for nothing. the guy who listed the "54" ford hood and front fenders 4 sale were actually "52's" waaaaaaa
. i guess it was too good to be true.....they were rags anyway and if they were 54's i wouldn't have bought them. he said they were in good shape...not really.hope the evaluation of my 4.6 turns out better than that.
q in 'cuse
shi--- happens & then you buy a che--- (no, not yet
