351w 289heads cam selection
Old Nov 6, 2012 | 07:37 PM
caste5ae's Avatar
caste5ae
i have a 94-96 351w with e5ae 289 heads, im using 750cc carb, flat top nylen pistons, stock exhaust, mallory duel points distributer any ideas on a great truck cam i can go either roller or flat tappet ???
Old Nov 6, 2012 | 09:09 PM
Conanski's Avatar
Conanski
Ahh... no you don't, E5AE represents a 1985 casting and the last year for the 289 was 1968, and besides that any 289 head will completely strangle this displacement so lets hope that's not what you have.
man.. I don't want to be too critical but that's got to be the worst combination of parts possible, are you just trying to produce a functional engine with what you got on hand? If so I say don't waste a dime on a cam just run what's in the block.
Old Nov 7, 2012 | 06:58 AM
baddad457's Avatar
baddad457
Nylon pistons ? As with what Conanski said, E5AE heads are not 289 heads. They're the "generic 302/351 head used in 1985. The dual point distributor is obsolete and for all intents and purposes today............quite useless. (unless someone pops a nuke in the atmosphere)
Old Nov 7, 2012 | 02:08 PM
85e150's Avatar
85e150
"Nylon", that's what I thought. But they are "Nylen", a brand of cast pistons:
Nylen Brand Cast Piston P746H40 H273CP40 1254P040 | eBay
Good to 10,000 rpms with 25psi boost.
Old Nov 7, 2012 | 05:25 PM
caste5ae's Avatar
caste5ae
abot the cam
these are 68 heads small chamber etc, the piston company that made the pistons are out of business, i was asking about cam selection if you don't know say so if you don't have a clue how to build torque on a budget stick with your corolla
Old Nov 7, 2012 | 06:02 PM
xlt4wd90's Avatar
xlt4wd90
The date code E5AE says it's 1985. Are you sure the code was not C5AE?
In any case, it's like Conanski says, the heads for the smaller engine would choke the 351, no matter what cam you used. Having said that, I note that in late 70s-early 80s that both the (non-HO) 302 and 351 used the same choking heads with the tiny valves.
Old Nov 7, 2012 | 06:10 PM
caste5ae's Avatar
caste5ae
hay
does any know anything about a good cam for a 351w ?
Old Nov 7, 2012 | 09:00 PM
big vann's Avatar
big vann
OP,didn't you post a similar question in the 80-86 truck section?You posted under the user name mortonhydraulics.You insulted the people who were trying to help in that section as well.Not the best way to get helpful info.Conanski and baddad457 have a lot of knowledge about SBFs.Were you referring to Adam Corolla?
Old Nov 7, 2012 | 09:36 PM
baddad457's Avatar
baddad457
Damn I need to get a set of those.
Old Nov 8, 2012 | 12:48 AM
85e150's Avatar
85e150
Here you go, all the cam you'll ever need:
COMP Cams: Dual Energy™, 255DEH <BR> Good Torque and Mileage, Smooth Idle
Old Nov 8, 2012 | 06:39 AM
baddad457's Avatar
baddad457
He cannot ask for advice on a cam without first telling us what his comp ratio is. If he's got flat tops in a 351W, combined with 54 cc 289 heads, then he's not going to be able to use a cam that increases the dynamic compression ratio. and still hope to run it on low octane pump gas. Too many "unknowns" here.
Old Nov 8, 2012 | 08:25 AM
85e150's Avatar
85e150
He asked about a "good cam for a 351w". He does not seem concerned about much else.....
Old Nov 8, 2012 | 04:16 PM
mortonhydraulics's Avatar
mortonhydraulics
comp 11.0 - 1
Old Nov 9, 2012 | 05:15 PM
FordFETruck's Avatar
FordFETruck
Good luck running that on 87 or 89 octane with 11:1 CR, it will most likely ping like crazy. I probably laughed harder than I should have at this.
Old Nov 9, 2012 | 07:27 PM
caste5ae's Avatar
caste5ae
i dont run that ethanol 89 crap anyway
