i talked to grabz about this and bought an another roof brace from tom in tucson, for more support but i'm not having verymuch luck at heat swrinking the roof
has oil canning bad from welding and people walking on it
any ideas out their
roy
I have a spare cab here in Glendale with a good roof.
Garbz
thanks garbz for the offer well keep you in mind
i'm still trying to fix what i have
i'm in nor cal but also in tucson alot
thinking about body man help next$$$$
roy
Have you tried felt stripping? Between braces and sheet metal. Like Ford did under the hood.
no haven't a friend said something along that line
like trying to picture what you mean 1/4 x1/4 angle spoted to roof?
i was thinking spray foam insulation in the roof braces but need somthing between
A roll of foam rubber weather stripping from your local hardware store would work. The one sided sticky stuff. Stuff some strips in-between the stiffener/support and the roof.
Tip: don't peel backing off sticky side until the foam in place.
Shrinking metal is and art that I could never master.
Best idea is to head to Glendale and get a new roof.. LOL.
Bring Sawzall.....
I can't cut the cab up and need help. LOL
Garbz
lol ;friend spent a week in hospital with hart attack he just got out so i feel your pain
myself just got a 1/2 new knee(one week ago) in at 5:00 am out at 2:00pm same day
big time drugs
roof this not a show truck i'm in capable of that quilty work
but learning along the way
thanks garbz
roy btw how close are you to stadium?
The stadium is about 11 miles from my home by road. about 8 as the crow flies.
Garbz
on another thread was talkin about roundabouts
well wickenburg is my favorite city in az i love it
the buypass roundabout 60&93 can't ever get it
two roundabouts it the southern one kills me!
Stud Welder Dent Pulling System - Auto Dent Repair Tools - Dent Pullers - Eastwood
Most of these guns have a shrinking tip with them. I have one similar to this that I used to take the oil can effect out of my roof. I bet that I had at least 100 shrinks in it to get the roof tightened up. After you heat it, cool it off with a damp rag immediately to make it shrink.
Kevin:
Im having a similar issue with the side of truck box. Ive seen guys use a torch with a welding tip on it. How big of an area did you heat up with the stud gun?
