Sponsored by: Real Truck
2001 transmission problem
Old May 21, 2003 | 09:14 AM
ldcattle's Avatar
ldcattle
My buddy has a 2001 F250 4X4 with a 5.4. His check engine light came on as well as the overdrive light on the shifter started flashing while driving on the highway. When he comes to a stop, it's sluggish to take off.
The independant shop says it's the Speed Sensor. The dealer then did a diagnostic check. The dealer says it's not the speed sensor, but something inside the tranny. They say the tranny must be dropped to locate the problem.
The truck only has 40,000 miles. Could the tranny be going out this soon?
Any other ideas?
Old May 21, 2003 | 09:27 AM
Waxy's Avatar
Waxy
I'd start with the speed sensor. They're only about $25 and you can do it in 5 mins in your driveway. If that doesn't solve the problem [u]right away[/b], then it likely is a transmission problem.
It's not common, but also not unheard of, to have tranny problems with 40,000 miles. Though it's usually the diesel guys that have problems with mileage that low. Did you do the fluid flush and replacement at 30,000?
Hopefully Mark K. will be by to give you some better trouble shooting ideas as to what the problem could be inside the trans.
Waxy
Old May 21, 2003 | 10:51 AM
daimon1054's Avatar
daimon1054
I had the same thing it was the throttle body that went bad. Changing all the sensors will just be a waste of money if they are not the problem. Go to a qualified mech.
Old May 21, 2003 | 11:04 AM
Waxy's Avatar
Waxy
The throttle body caused those transmission symptoms? That's a new one on me.
Unfortunately, going to a "qualified mech" can be far more expensive (having them bill you to drop and inspect your trans. when all you needed was a $25 sensor) than some simple trouble shooting. The symptoms described were pretty consistent with the speed sensor going bad.
I'm sure Mark K. will be along to give you the right answer.
Waxy
