Hey, I'm working on an older alignment machine that can't connect to the internet to look up the specs...I have a 86 f-350 4wd,4 door and need the toe-in specs. Anyone have them or know where to find them?
Thanks
FOUND SPECS!
I thought I'd post them up in case some one else funs into the same issue I had.
88-85 f250 and f350 solid front axle 2 and 4wd:
TOE Inches :
-0.09min/0.03preferred/0.15max
TOE Degrees:
-0.19min/0.06preferred/0.31max
Reason: found specs
