Scored at pull apart
Old Nov 4, 2012 | 08:21 PM
rangergirl94's Avatar
rangergirl94
I found a small block zf got it for 82$ but the shifter isnt in it do these take bushings? And will my stock drive shaft work I have m5od in my truck?
Old Nov 5, 2012 | 08:20 AM
garthneddy's Avatar
garthneddy
The shifter is suspended in two plastic bushings. I believe I got some replacement pieces at my local Ford dealer for a reasonable price, although I can't remember how much.
I believe the transmissions are within a half inch of each other in overall length, so you should be able to use your original driveshaft.
I always seem to just miss all the great deals in the yards around here. This spring I happened to get to the yard just as a couple guys started pulling a 7.3 powerstroke. Since the local yards charge only by the number of cylinders an engine has, they scored the complete motor for a measly $143
Old Nov 5, 2012 | 10:18 AM
rangergirl94
Ya I was really surprised it was still there I only ever seen 2 zf trucks and the trannys were gone I didnt intend to spend any money lol fail
Old Nov 6, 2012 | 05:40 PM
rangergirl94
Anyone know where I can buy a used shift tower and how much they go for? Thanks
Old Nov 6, 2012 | 06:31 PM
EPNCSU2006's Avatar
EPNCSU2006
The answer to the question about the driveshaft depends on if the truck is 4x2 or 4x4.
You can find an exploded view in the documentation on ZF's website under catalogs and technical literature: ZF Friedrichshafen AG | Replacement Parts for Passenger Cars
timmyboy76
13
Sep 6, 2016 05:13 PM
IDIDieselJohn
Dec 12, 2013 10:51 PM
masseysbronco
1978 - 1996 Big Bronco
Nov 11, 2013 06:02 PM
Tyler_J
Nov 23, 2005 08:40 PM
