Sponsored by: Real Truck
Lighted Mirrors
Old Nov 4, 2012 | 05:13 PM
Fuzzynemo's Avatar
Fuzzynemo
Lighted Mirrors
Will the side mirrors with blinkers and marker lights fit on an 01 F250? And is it already prewired for them? I just like the way they look.
Old Nov 4, 2012 | 05:32 PM
Punisher29073's Avatar
Punisher29073
I am looking to make this mod as well. Any info is double appreciated.
Ryan
Old Nov 4, 2012 | 05:40 PM
BigPigDaddy's Avatar
BigPigDaddy
They will bolt on, but the electrical plug is different because the older trucks are not wired for them. I believe 2003(?) was the first year for the signal mirrors. Plenty of folks have upgraded, so there are threads detailing the process.
Old Nov 4, 2012 | 05:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
They bolt on, and they will "plug" in. And by that I mean they have the same connector. Or at least should. They used a round up to 2001 and in 2001ish they moved to the rectangle that the new mirrors have. So hopefully yours have the rectangle. Now, they wont be WIRED for the signals, markers and heat. You will have to run those wires yourself.
Old Nov 4, 2012 | 06:02 PM
BigPigDaddy
I stand corrected. I thought the plug change did not take place until the lighted mirror change.
Old Nov 4, 2012 | 06:04 PM
Firefighter 1406's Avatar
Firefighter 1406
Easy mod. Tap into the turnsignal and running light wires behind head light switch, run there the door loom and good to go. Put 06 king ranch mirrors on my early 99 and it took just a couple of hours.
Old Nov 4, 2012 | 06:27 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
No worries! The actual change over, like most Ford change overs, is a grey area.
brandon.edwards
Mar 24, 2014 11:09 PM
1976and2001_250
Dec 7, 2010 06:51 PM
Seven-Point-Three
May 29, 2010 12:10 PM
74bruce
Dec 14, 2009 11:32 PM
Highmark18
Aug 23, 2009 11:06 AM
