1995 351 missing when warm
Old Nov 4, 2012 | 04:51 PM
andyj ford driver's Avatar
andyj ford driver
i have a 1995 f150 with a 351 and it misses when it gets to operating temp and it shakes at about 40-45 mph i went to oreilys and read the codes and it didnt show any, where should i go from there.
Thanks
Old Nov 5, 2012 | 07:37 AM
rla2005's Avatar
rla2005
Clean the contacts on the data link connector. If the reader actually connected to the PCM you should have gotten the all clear code of 111/111 for KOEO tests and 111/111 for the Continuous Memory display if the tests passed and no codes stored in memory.
Anything less means your test is invalid.
Old Nov 5, 2012 | 11:33 AM
andyj ford driver
im sorry it showed code 111 for system pass that is all it showed
Old Nov 5, 2012 | 11:44 AM
rla2005's Avatar
rla2005
Thanks for the clarification.
Next set of questions: How old are the plugs/wires/cap/rotor and filters? Never ignore the basics.
Old Nov 5, 2012 | 11:56 AM
andyj ford driver
they have all been changed in the last 20000 miles
Old Nov 5, 2012 | 12:52 PM
rla2005's Avatar
rla2005
20k and how old?
I would pull the plugs to see if any of them show signs of oil/rich condition. If the plug wires/cap/rotor were cheapos from Advance or AutoZone, etc. they could already be trashed. A visual inspection will tell you a lot.
Old Nov 5, 2012 | 06:34 PM
andyj ford driver
they are a year old and they are autolite plugs and wires form napa. would a plug that is not gapped right cause it to miss
Old Nov 5, 2012 | 07:57 PM
rla2005's Avatar
rla2005
It sure could.
What about the cap and rotor? age/miles/brand/did you inspect them...
Old Nov 5, 2012 | 09:17 PM
andyj ford driver
they are whatever brand it is that napa sells i havent had a chance to pull the plugs yet i will try to do that tommorow
cap and rotor were changed at the same time as the plugs and wires
andyj ford driver
Nov 28, 2012 10:26 PM
Roy Jackson1
Jun 30, 2010 07:55 AM
geraldo14
Apr 12, 2008 10:20 AM
bkampbel
Oct 7, 2005 04:53 PM
BigFord1977
General Automotive Discussion
Jan 30, 2004 09:20 PM
