Front cover
Old Nov 4, 2012 | 04:08 PM
blk92prostreet's Avatar
blk92prostreet
Front cover
How many miles before the front cover of a 2000SD with a 7.3 turbo wear out causing low oil pressure from the LPOP? THANKS tom
Old Nov 4, 2012 | 04:34 PM
pin8246's Avatar
pin8246
Around here people don't really base thing on mileage. It's more along how well the truck is taken care of, and the part of the world you live in. up north will have more problems than i do in Texas due to salt on the roads in winter.
Old Nov 4, 2012 | 04:37 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
I am not sure. My 2001 has 219000 and I have not had any problems with the front cover. I had to replace the o-rings on the oil cooler. But it wasn't because of low oil pressure. I was having signs of a water in my oil. This lead to replacing the o-rings. What are all of the issues you are having? Someone with more knowledge than I will chip in.
Old Nov 4, 2012 | 05:55 PM
Kdr358's Avatar
Kdr358
The front cover does not wear out. The LPOP itself could be leaking or weak. What issues are you having thats pointing you to the front cover? I have 282,000 miles on mine and never even touched it. I dont think anyone ever had too.
Old Nov 4, 2012 | 06:03 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Sounds like you have a cavitation issue. This comes from poor cooling system maintenance; unfortunately this is VERY common. You need to do a coolant flush. Also I would remove the water pump to inspect the front cover behind the pump. Once you are all done and if you are satisfied with what you see, look into ELC; Extended Life Coolant. Its usually red, and wont cause cavitation along with some other benefits.
Old Nov 4, 2012 | 06:07 PM
Kdr358's Avatar
Kdr358
It Wouldnt cause low oil pressure would it?
Old Nov 4, 2012 | 07:23 PM
Christof13T's Avatar
Christof13T
You dont want to be aggressive when dealing with any component that is attached to your timing cover. IT IS VERY FRAGILE! If you crack it, or break a threaded mounting hole... its done... and the engine MUST come out to replace it without causing massive leaks post install. This process is no joke. The motor weighs in at about 1200lbs when its ready to come out. It took the assistance of my engine crane to even turn the motor upside down on a 1ton engine stand. Massive.
You can pull everything off the front of your timing cover and have a look...but i doubt there will be an issue unless the engine has been mistreated.. i.e. overdue oil changes, run hot, worked to hard, poor fuel maintenance, etc...
The pump side of my cover after 398,000miles or so when it was pulled... had a couple scratches in the pump surface undercut. I put the old pump back on with the replacement cover and shes running like a champ. Almost at 401,000 now.
The old timing cover was still doing just fine even with the wear... but i broke a oil cooler mounting hole. A piece of the cast aluminum was fused to a bolt and was pulled out with the threads and expanded the hole enough to break the housing. Buncha fun.
What leads you to believe you have a problem with your lpop?
Old Nov 5, 2012 | 06:48 AM
blk92prostreet
Front cover
Hi Guys
I'm kinda jumping ahead to condemn the front cover from my idiot gage on the dash. The 2000 7.3 has 150k on the clock and has given me 21mpg, just love this truck.
I thought if the sender didn't SEE 7psi the ECM would not supply oil to the injectors or HPOP to protect the engine from damage. It starts with no reading on the dash gage for 2 sec when cold
I think the first step is to replace the sender because it has a delay before it swings up on cold start up. I DO NOT have any other issues, like sounds of a rod knock or piston slap on cold start up. The truck runs great.
To satisfy my actual pressure curiosity I'll hook up a pressure gage and see what I have. I've been told that there are 3 possible testing ports. Which one would be your best choice?
I've been on other Diesel sites for some time and appreciate all inputs. Since I can't put my signature on yet: 2000 SD CC SB 2WD AUTO 3.7 150K ITP Reg. Rtrn. AFE,Magnaflow 3.5''dp,4''back foil delete, zoodad mod,Hpx,.450 sonnax mod,DP 80e 80tF-5, autometer pyro and boost
Thanks for your inputs Tom
Tom
Old Nov 5, 2012 | 08:13 AM
kawcrasher's Avatar
kawcrasher
I would blame the pump long before the cover. My truck has 360k on it and a friend has a van with around 700k on it and both covers are fine.
Old Nov 5, 2012 | 08:34 AM
blk92prostreet
Front cover
WOW!! those 7.3's are Amercian made work horses !!! Its not uncommon that most go over 500k if you take care of them
Tom
Old Nov 5, 2012 | 01:02 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by blk92prostreet
I'm kinda jumping ahead to condemn the front cover from my idiot gage on the dash. The 2000 7.3 has 150k on the clock and has given me 21mpg, just love this truck....
Sounds great. Nothing to fix here. As already mentioned...the front cover does not wear out (provided the coolant is properly maintained...)
I thought if the sender didn't SEE 7psi the ECM would not supply oil to the injectors or HPOP to protect the engine from damage. ...
No ECM on these trucks. ECM implies that there is a separate TCM which there is not. We have a PCM which controls the engine and transmission together...(at least for automatic trans vehicles). At any rate, the PCM does not look at the low pressure oil value, that sensor is strictly for the instrument cluster. If the LPOP system is working correctly, then the HPOP receives oil. The PCM only controls how much high pressure oil makes it to the injectors. Without adequate low pressure oil volume, the engine will shut down because the injectors will starve for oil....the injectors use oil pressure to inject the fuel charge.
... It starts with no reading on the dash gauge for 2 sec when cold...
Very common. Nothing to fix here. If your engine would start and then die a few seconds later then we would be talking about changing the LPOP...
To satisfy my actual pressure curiosity I'll hook up a pressure gauge and see what I have. I've been told that there are 3 possible testing ports. Which one would be your best choice? ...
I have attached a pdf file that may help.
Old Nov 5, 2012 | 01:43 PM
Crewcab Turbo's Avatar
Crewcab Turbo
A weak LPOP will cause a delayed oil pressure gage. I had a slow to rise oil pressure gage at startup , I installed a Melling LPOP and my oil pressure comes up quick now.
Old Nov 5, 2012 | 01:58 PM
blk92prostreet
Front cover
Thanks for the time.......... Shake-N-Bake
I should have started the thread saying : dash oil gage needle does not swing when mtr starts.. within 2 sec. but runs fine!
Old Nov 5, 2012 | 02:38 PM
Shake-N-Bake
That gauge on some trucks pop right up and others take a bit more time. My personal truck takes a while before the gauge registers pressure.....been that way since it was new. Lab reports on the oil don't show any excessive wear or any problems that I am aware of. I'd leave it alone unless you are having other symptoms or you really want that needle to react more quickly. If so, then a Melling pump is your solution.
ColoradoFordBoys
Aug 28, 2014 06:10 PM
erik68
May 23, 2013 10:28 AM
fordbronco1966
Nov 24, 2010 09:33 PM
origcharger
Dec 30, 2009 07:30 PM
offroadguy
Jun 21, 2003 07:31 AM
