Can not move distributor
Old Nov 4, 2012 | 01:53 PM
JimG1098's Avatar
JimG1098
Hi gang,
Doing a little work on the truck and went to check and adjust timing. I loosened the nut holding the dist. down, and can not move dist in either direction. Taped on a purchase point with a wooden block and hamer, still not moving. Not sure weather to put rust blaster in the joint or what.
Any ideas will be appreciated.
Thanks
JimG
Old Nov 4, 2012 | 02:04 PM
Dale Fairfax's Avatar
Dale Fairfax
Must be a Y-Block. The rust blaster won't hurt-but may not help either.
Old Nov 4, 2012 | 02:12 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Jim,
Wow, I've never heard of that happening before. I can see how it could happen though. I'd give the penetrating oil a shot. Let it sit for a while and then try tapping on it again.
Either that or leave it alone (depending on where the timing is at).....lol
Bobby
Old Nov 4, 2012 | 02:36 PM
Eds56Effie's Avatar
Eds56Effie
Same problem I had when I got my 56 F100 w/351W as it had been sitting for a long time..wouldn't budge in either direction. I finally sprayed the hell out of the shaft for several days with PB Blaster and used an oil filter removal tool around the base of the distrib. and kept working in both directions until it finally freed up. No damage to the distrib resulted..but, it pretty much ruined the tool.
Good luck.
Old Nov 4, 2012 | 03:38 PM
JimG1098's Avatar
JimG1098
Dale, Ed and Bob
thanks for the assist.
Yes it is a Y block, 279, 54 ford F-750
I will PB blasyter it during the week and try next week end.
Had a pipe wrench on it, no go. I was afraid to really pull on it with thge wrench. I like the oil filter wrench set up better
JimG
Old Nov 4, 2012 | 04:08 PM
bobbytnm's Avatar
bobbytnm
LOL, that would really suck if you twisted it off with that big old pipe wrench. There would definately be some cussing going on then
After you soak it for a bit then maybe try tapping around the base of it, who knows, maybe it will help break things loose.
Again, good luck
Bobby
Old Nov 4, 2012 | 04:16 PM
JimG1098's Avatar
JimG1098
Just went out to garage and gave it a blst of PB. We'll see
Old Nov 4, 2012 | 05:12 PM
Harrier's Avatar
Harrier
I'm glad to hear that I'm not the only one with this issue. I loosened the nut and nothing. At that point in my build I left well enough alone. Once I get my cooling system operational I will be able to turn my attention to timing (and carb tuning). This info will definitely help.
Old Nov 4, 2012 | 08:11 PM
The Horvaths's Avatar
The Horvaths
Read here:
http://www.enginebuildermag.com/Arti...rd_tricks.aspx
Old Nov 4, 2012 | 09:06 PM
eman92082's Avatar
eman92082
Had to be a Y-Block. Well placed explosives or latching it to a crane while pounding on it may help. Sorry, don't mean to be a smart-a$$ but this is a well known issue .
It won't hurt to try blaster. I think I eventually got it to move with a BFH and a wood block but I took my time.
Good Luck
Old Nov 10, 2012 | 11:58 AM
JimG1098's Avatar
JimG1098
Hi gang,
Went to the truck today to mess with the distributor. Here is what I found.
I totaly remove the nut and clamp and could see very slight movement. I then went to my manual and on pag 103 was a blow up of my distributor.
What I realized was that the reason it would not move is because the governor body is held with this nut and clamp and stud . I would believe that the 2 piece clamp that holds the governor body to the distributor is what I have to losen.. I have put a picture of this in my albul titled distributor. You can see that right above the word lockwasher near the bottom of the shaft, there is a place for the stuc to go thru, hence, it will not turn. I am attempting to get that diagrame in this post, but I may not be sucessful.I
javascript:smilie('')
Old Nov 10, 2012 | 12:58 PM
JimG1098's Avatar
JimG1098
That was the ticket gang. Losened up the clamp holding the dist body to governor and adjusted timeing. ALL IS GOOD
JimG 1098
Old Nov 12, 2012 | 10:45 AM
bobbytnm's Avatar
bobbytnm
Wow, I'm glad you figured it out. That would have really sucked to tear into it with a pipe wrench and destroy the thing....lol
Bobby
Old Nov 12, 2012 | 04:15 PM
JimG1098's Avatar
JimG1098
Yea, Bobby. I am glad I had the shop manual with pictures. I had never seen that set-up before on a distributor. All the ones I work on back in the day, did not have governors. so that was new to me.
Learn something every day on this project, That is what makes it great.
JimG 1098
Bud Mud
May 20, 2014 10:51 AM
bustedflush
Jun 3, 2007 01:00 AM
NJ239Y
Aug 28, 2005 05:02 PM
trinogt
May 30, 2002 12:50 AM
CollinsCD
Feb 7, 2002 09:08 PM
