AE, CCT and Injecor Buzz test
Old Nov 3, 2012 | 08:49 PM
srteach's Avatar
srteach
I finally used AE on my truck (shown below) 2001 7.3 CCLB, manual 6 spd., 263K miles
Found the following CCT shows #3 & #8 low, buzz test sounds strong and even. Planning the following:
  1. do 50 cent mod
  2. torque all bolts under VC
  3. check UVCH wiring for chafing
  4. ohm out all the GPs
No money for GPs. Any suggestions on planned follow up or other things to think about while I'm under there?
Old Nov 3, 2012 | 09:20 PM
JT250's Avatar
JT250
Founder the following CCT shows #3 & #8 low, buzz test sounds strong and even. Planning the following:
  1. do 50 cent mod
Have you checked the price on glowpugs? They are very affordable even from the dealership which is the ONLY place you should get them.
Old Nov 3, 2012 | 09:35 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
#3 and #8 showing worse than the others is normal. A different CPS such as an original black one may improve the numbers. Unless the numbers are dramatically bad it is nothing to worry about.
Old Nov 3, 2012 | 09:47 PM
SkySkiJason's Avatar
SkySkiJason
What CPS do you have?
Look at Rotational Velocity for all (8) cylinders and see what those values are. If it runs smooth, don't worry about it no matter what they are!! Either data log those values and/or write'em down so you can compare later.
As far as GP's go - OHM them out and see what they are. IIRC, anything under 2 ohms is good. No reason to replace them if they ain't broke and if yer poor, no harm in doing a couple if they're not good. Use Motorcraft ZF11 GP's, available at autoparts (~$10-11ea) - don't use aftermarket GP's, specifically Autolite.
You wanna look at the harness going to the 42pin connector and make sure its not chafed where it goes over the VC.
Not under VC, but go ahead and 'fix' the OD wire where it crosses over the steering column if ya haven't yet.
https://www.ford-trucks.com/forums/1...tch-short.html
Old Nov 3, 2012 | 10:30 PM
Stewart_H's Avatar
Stewart_H
Ummm, no.
Riffraff Diesel: Motorcraft Glowplugs
Heh, I couldn't help myself. I know what you MEANT to say was buy only Motorcraft glow plugs.
Stewart
Old Nov 4, 2012 | 05:53 AM
Pitcrw6's Avatar
Pitcrw6
Clays got free shipping on GPs right now and that helps when going to the east coast.
Old Nov 4, 2012 | 08:07 AM
BadDogKuzz's Avatar
BadDogKuzz
Rob where did you see that Clay had FREE shipping on GP's ? Because with free shipping that is a deal!
Old Nov 4, 2012 | 08:36 AM
howellt39's Avatar
howellt39
As long as the hood's open and along the same lines as the OD switch wiring in the steering column, check your 42 pin wire group where it runs over the driver's side VC, chafing happens on the underside. Same wire group at the driver's side shock mount is also a problem area. Armor as necessary. If it wears through it'll ground out on the VC and blow fuse 31, putting you on the side of the road. So I've heard........
I don't have it installed yet, but I purchased the HPx mod from Riff Raff, and it's a pretty simple, inexpensive tube that runs under the turbo spider and connects the high pressure oil systems in each head. From what I understand, it evens out the oil pressure, helping injectors fire more evenly. There's a lot of guys on here that can surely comment in much greater detail on its effectiveness, but possibly something to consider to even out your injector performance pending what they have to say.
Lastly, be sure to read a couple threads about the VC's, there's some helpful tricks to getting the more difficult bolts out people here have discovered. As always, an excellent resource.
Old Nov 4, 2012 | 08:59 AM
srteach's Avatar
srteach
Manual trans, no OD. I have the HPx (it's in the sig below) . I will check (and reinforce) the wiring on top of the VCs and shock mounts.
I currently have the "C" version of the CPS, proactively changed a few months ago, with a backup "C" version in the under back seat storage box.
I am barely keeping fuel in the truck, so no GPs unless they ohm out bad. I will only buy motorcraft GPs due to the information found here.
Thanks for the responses, guys and gals.
Old Nov 4, 2012 | 09:02 AM
1fixitman's Avatar
1fixitman
The best deal on zd11 glowplugs that I have seen is 80$ shipped on ebay for a set of 8.
Old Nov 4, 2012 | 09:57 AM
PaysonPSD's Avatar
PaysonPSD
This is a Ford Special Service Message posted by Nolan (4inchlovin) about "Phantom Codes" after running a CCT.
Old Nov 4, 2012 | 11:01 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Riffraff Diesel Performance Parts: - On Sale
Old Nov 4, 2012 | 11:19 AM
Pitcrw6's Avatar
Pitcrw6
Ed, you asked and you received from the man himself. Also Clay posted it on FB also which is why I have a FB account and he has free giveaways once a week on FB. He just had a AE giveaway about a month ago. Most on here will say they will never own a FB account, that just leaves a better chance for me to win.
Old Nov 4, 2012 | 11:29 AM
BadDogKuzz's Avatar
BadDogKuzz
Originally Posted by Riffraff Performance
Good deal Clay and great timing !!
I'll get my order in as I get a chance to see what I need. When does this sale end and free shipping end?
jwoo99
Mar 1, 2017 08:45 AM
SpringerPop
89
Apr 23, 2015 09:26 AM
commandersander
Sep 18, 2012 07:05 AM
540milotalon
Nov 3, 2011 09:03 PM
PSNut
26
Jul 17, 2008 07:30 PM
