2003 Expy Won't Accel
Old Nov 2, 2012 | 04:57 PM
creed7276's Avatar
creed7276
Could somebody tell why when I try to accelerate I get a very loud bumping sound that comes from my muffler. It misses and sputters and it's very hard to even get to around 50 MPH.
2003 expedition XLT 4X2
5.4
Old Nov 2, 2012 | 05:01 PM
khadma's Avatar
khadma
Carpenter Local 745
Is your check engine light on?
When was the truck last serviced?
Old Nov 2, 2012 | 05:17 PM
creed7276's Avatar
creed7276
Yes code P0174
Old Nov 2, 2012 | 05:30 PM
khadma's Avatar
khadma
Carpenter Local 745
Do you have a K&N air filter?
You may have a dirty/damaged MAF sensor or there is an air leak after the
MAF sensor.
Clean the MAF sensor or test/replace.(disconnect negative battery cable
before doing any work). May need to test drive the truck for 10 minutes
after.
Check for loose or damaged vacuum lines/fittings.
THE ABOVE IS JUST FOR STARTERS.
Old Nov 3, 2012 | 02:13 AM
alloro's Avatar
alloro
Check the fuel pressure. You either have a bad fuel pump (or regulator), or because of the P0174 code, a very large vacuum leak.
Old Nov 10, 2012 | 09:21 PM
creed7276's Avatar
creed7276
Changed the #8 cop and it runs better but still gets terrible MPG and it stumbles on acceleration,but it will at least get up around 75. Could it more than one coil no codes P0174 has not reappeared.
Old Nov 11, 2012 | 09:06 AM
Deadstick 8409's Avatar
Deadstick 8409
Check the vacuum elbow behind the throttle body that runs to the pcv.
mperl93
Nov 30, 2012 07:42 AM
bazzman1953
1983 - 2012 Ranger & B-Series
Feb 27, 2012 08:53 AM
trip6721
Dec 31, 2009 07:52 PM
t0mkat
Jun 24, 2007 05:35 PM
dmo00
1997 - 2003 F150
Sep 8, 2003 11:18 PM
