Went to start, and thought I heard some strange quick noise under the dash.
Turned key on, no instrument lights, no power to anything.
Relay #1 under dash (interior lights) is clicking while interior light is dimly dimly blinking. Only sign of power any where in truck.
Batteries measure 12.75 (ds) and 12.34 (ps).
Had a guy provide a jump.
After connecting cables, turned key on, everything lit up normally, then within 2 secs, go back to orig problem state and no start or power except for clicking relay and slow blinking interior light.
Stuck now in Vegas without a clue where to go on a Friday.
I'm thinking its battery time. Mine went pretty much over night. The batts had normal voltage, but not enough amps to turn the engine over.
I also heard some strange clicking/ weak buzzing under the dash.
Had your batts load tested at a parts store. It's usually free.
Walmart has decent batts at a decent price, and if they ever let you down its not hard to find a store to return them.
My truck flashed the interior lights like that when the batteries were dying. I just had a simple multimeter and while the voltage checked out, the amperage was way low. I couldn't tell that with a multimeter.
Had my batteries load tested and they both failed miserably. Replacing both corrected my problems. Recommend having your batteries tested with a load tester.
X3 on the batteries... my batteries got so bad that my truck slowly started shutting down while I was driving, dimming lights, radio failure, then truck quit, same thing, gauges go haywire and then nothing.
Like said, get your batteries tested and plan on grabbing a couple new ones. On a side note, if one battery tests bad and the other good, GET TWO!
Good luck, if it turns out to be something more, let me know. I can make some phone calls and help find you a quality shop in Vegas. If I still lived there, I would be on call to lend a hand of course!
My dash lights freaked out like that when my gem and fuse box were water drunk.
I had the similar no starter engage symptom for 2 turns of the key but then started working.
Being that you are in vegas i couldnt imagine the commonly known "leaky windshield" syndrome being your culprit in this case... but the symptoms being so similar i thought i might bring it up. The fix for my leaky windshield syndrome ended up being a reseal job on my cab marker lights.
What did the shop tell you? Interested to hear the resolution in case you've got something more serious on your hands than a pair of batts. Hope it's that simple though.
If you have not already done so, I suggest pulling battery cables and thoroughly cleaning both cables and posts (all four) many batteries are sold because of a bad connection. Just say'in.
Edit: sorry I was late to the party, please post resolution.
