Will the front end leveling pucks work?
Old Nov 1, 2012 | 08:06 AM
scorpion48's Avatar
scorpion48
Ordered a set of leveling pucks for my '95 F150 XL 2wd. Now I have read that they will not work on an XL. Has anyone installed these on their XL? I thought that these trucks were vertually the same XL and up as long as it was 2wd to 2wd. If this doesn't work what is the major difference in the XL from all the rest? Thanks.
Old Nov 1, 2012 | 10:53 AM
fdude64's Avatar
fdude64
i thought the xl was the type of interior package the truck had
Old Nov 1, 2012 | 11:18 AM
SideWinder4.9l's Avatar
SideWinder4.9l
It is the same, 2wd is 2wd...XL is trim package (Power windows/Manual Windows, etc)
You're correct on this...XL/XLT/etc is all just trim packages...
Old Nov 1, 2012 | 11:31 AM
scorpion48's Avatar
scorpion48
Thanks
I thought I was right about that. Don't know why they have them listed as they won't work on XL.
Old Nov 1, 2012 | 11:39 AM
SideWinder4.9l
Because companies do the listing, SEVERELY uninformed as to what actually works/does not work...
Old Nov 1, 2012 | 02:26 PM
FordYoungGun35's Avatar
FordYoungGun35
Say I buy the 2 inch leveling picks that he's talkin bout will I need to do anything like alignment and what not
FordYoungGun35
And would there be a bumper gap?
Old Nov 1, 2012 | 03:07 PM
Nickk97tml's Avatar
Nickk97tml
like these? They fit my 2wd XL? and no there won't be a bumper gap.
watch this video, I shove my camera in my fender you'll see them:
Old Nov 1, 2012 | 11:34 PM
FordYoungGun35
That's the exact kit I'm lookin at, can you run me though the install and things i need to do before and after... Like alignment or anything..
Old Nov 2, 2012 | 02:55 PM
Nickk97tml's Avatar
Nickk97tml
its almost common sense:
-remove wheels
-remove coil spring bracket (at top of spring)
-remove coil spring
-tighten stud extenders (included)
-place the spacer
-add the coil spring
-tighten coil spring bracket
-tighten wheels
when you have it on jack stands, place the stands on the frame to let
suspension cycle down letting you have room to play and easily squeeze the
spring back in.
Old Nov 4, 2012 | 07:24 AM
FordYoungGun35
I mean like afterwards do I need to go get an alignment or anything of that sort
Old Nov 4, 2012 | 11:10 AM
Nickk97tml's Avatar
Nickk97tml
sorry, yeah your going to need an alignment.
Old Nov 15, 2012 | 03:01 PM
scorpion48's Avatar
scorpion48
update- They don't fit! The bolt extention is way to small. My bottom retainer nut is 1 1/8". The extention that comes with the kit is 1" or smaller. so I'm keepin the lower front end for now.
Old Nov 15, 2012 | 04:45 PM
Nickk97tml's Avatar
Nickk97tml
1995 f150 leveling 2wd | eBay
basically its which ever one catches your eye best
scott.sanders
2015 - 2020 F150
18
Sep 2, 2018 06:20 AM
crisman
May 3, 2018 02:41 PM
wallysford
Jan 29, 2013 03:19 PM
xdavis22
Jan 11, 2011 04:47 PM
Half Breed
Mar 2, 2007 01:40 PM
