Leak
Old Oct 31, 2012 | 08:56 PM
Drzr's Avatar
Drzr
Ok...but I got a coupon last week from my dealer to change both for 99.99.
Old Oct 31, 2012 | 09:29 PM
Drzr's Avatar
Drzr
Originally Posted by tolliewolly
That filter ain't cheap. Just a heads up too. Good luck!
Ok thanks...I got a coupon last week from my dealer to change both for $99
Old Oct 31, 2012 | 09:36 PM
kper05's Avatar
kper05
Buy a spare and throw it in the truck while you're at it.
When I'm due for a change, I use the one in the truck and replace the spare with a newer one.
I've never needed it but it's there if I do.
Old Oct 31, 2012 | 09:41 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
That seems like a lot for a fuel filter change, I wonder what the filters cost. I have only had my truck a month so haven't had to do anything to it but drive it. If you are not comfortable with changing them yourself the $99 dollar filter change might be the best bet. The other thing to check on is warranty if the fuel filter housing is cracked and obviously you haven't messed with it since you didn't even know what it was, maybe Ford will warranty it, it's worth a try.
Old Oct 31, 2012 | 09:50 PM
Drzr's Avatar
Drzr
I thought that was a GOOD deal! And although as mentioned I'm not mechanically inclined watching the video I think I'll try it. We will see! Again thank everybody for all of the replies.
Old Oct 31, 2012 | 09:53 PM
Drzr's Avatar
Drzr
And BTW @ Tim Young I hope if you and yours were in the storm you are secure. God Bless
Drzr's Avatar
Drzr
As well as ALL OTHERS!!!
Old Oct 31, 2012 | 10:06 PM
kper05's Avatar
kper05
The filter kit is about $60 with shipping online.
Old Oct 31, 2012 | 10:08 PM
Drzr's Avatar
Drzr
Well it'll be worth the $99 for ME!
Old Oct 31, 2012 | 11:02 PM
kper05's Avatar
kper05
Yes, because you need one now.
Old Oct 31, 2012 | 11:28 PM
Tim Young's Avatar
Tim Young
I agree if the filter kit is $60 bucks, $99 bucks to have the dealer change them would be a good deal. Is your truck still under warranty? I would hope that if it was cracked that it would be under warranty.
By the way Drzr I am in the North West, Washington State, no storms here.
Old Nov 1, 2012 | 04:43 AM
ruschejj's Avatar
ruschejj
That housing just holds a sealed filter, even if it is cracked, there shouldn't ever be any fuel in that holder. Has to be the filter itself or the connection of the lines is bad.
Please be sure to inspect the o rings and that those connectors are in good shape. Really don't want you to have a fuel leak on top of the motor!
Old Nov 1, 2012 | 07:43 AM
  #28
kper05's Avatar
kper05
If you're talking about my picture example, that's all I had to try to determine Dr's location of the issue.
I would have posted one with the filter in there if I had one.
My take from his description is the sealed filter plastic is cracked inside of that metal housing.
Fuel should be touching the inside plastic sidewalls of the sealed filter, correct?
It took a bit of a hit when I cracked mine open on purpose awhile back so hard to explain how it cracked.
Old Nov 1, 2012 | 09:21 AM
  #29
Drzr's Avatar
Drzr
Just took to dealer and no warranty out but service man said they have had several occurrences of this. Should be ready in an hour.
Old Nov 1, 2012 | 09:50 AM
  #30
kper05's Avatar
kper05
No warranty for what? Or do you mean recall?
So they've seen this sealed filter container cracked?
Do they know why?
