TROUBLE STARTING
Old Nov 3, 2012 | 03:28 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I wouldn't mess with this carburetor yet.
His truck is in limp home mode. No ignition timing advance, due to smog components disconnected. No computer fuel/mixture ratio adjustments, due to the smog control components disconected. It's all set a preset (limp home mode) values.
This can cause the hesitation he's describing, and why the timing is off.
As 83F1503004x4 stated the engine will not run right without those smog components being replaced, or a Duraspark-II, or other ignition system conversion done.
I would choose one of these courses of action and go from there.
If there are smog check requirements in your state, then you will have to fix what you got.
19BULLNOSE85's Avatar
19BULLNOSE85
ok cool ill look into that as well. again thanks
Old Nov 3, 2012 | 03:36 PM
Gary Lewis's Avatar
Gary Lewis
Wow! How'd I miss that. You are right, if he's pulled components off then all bets are off.
BullNose - It is literally all or nothing on those - either you have all of the stuff or you have none of the stuff. Nothing in between.
Troy conrad
Jun 23, 2019 11:09 PM
Encho
Feb 27, 2013 05:01 PM
Lead Head
1983 - 2012 Ranger & B-Series
17
Sep 19, 2007 10:19 PM
jln_Wasabi
Electrical Systems/Wiring
Mar 3, 2004 10:36 PM
ford429cu
May 6, 2002 05:43 PM
