Sponsored by: Real Truck
No power anywhere!!!????!
Old Oct 30, 2012 | 06:00 PM
Bradlyw's Avatar
Bradlyw
Working on friends truck,need HELP.Here is the problem:While removing relay in under hood box something shorted out resulting in no power anywhere. I've looked up problem on every resource that I have and can't find anything that addresses this.Thinking fuse link?Again, this is not my truck and I know very little about it (1998 f-250 LD)other than that it was running fine before short.Any help would be appreciated guys!
Old Oct 31, 2012 | 03:10 PM
Beerstalker's Avatar
Beerstalker
If it's really a 1998 F250 Light Duty (those are pretty rare), then you should ask in this section instead.
1997 - 2003 F150 - Ford Truck Enthusiasts Forums
The 1998 F250 Light Duty is more like the 1997-2003 F150. Ford actually stopped calling it the F250 Light Duty in 1999 or 2000 I believe and started calling it the F150 Heavy Service package, or something like that to try to reduce confusion.
Old Oct 31, 2012 | 07:51 PM
Bradlyw's Avatar
Bradlyw
Appreciate the info. I found that,for the most part,the electrical systems are identical to same year 150 and actually used a 150 schematic to trace(and resolve) problem this afternoon.Fusible link,ended up being a relatively easy fix.I actually asked the guy if he was sure that truck was a 250 and didn't just have 250 emblem! Like you said rare truck,pretty much a 150 with (slightly) stouter suspension!
97C5ENVY
Apr 20, 2009 11:34 AM
jerem0621
Apr 13, 2009 09:13 PM
ckinneavy
Apr 13, 2004 09:24 AM
Sherlock101
1997 - 2003 F150
Oct 3, 2002 05:55 PM
Edmo
Dec 17, 2001 09:59 AM
