Headlights not working
Old Oct 30, 2012 | 04:06 PM
Ranger Louie's Avatar
Ranger Louie
Headlights won't come on.They used to work but started flickering and quit working.(1993 Explorer).
Thanks in advance
Louie
Old Oct 31, 2012 | 06:48 AM
shorod's Avatar
shorod
What have you checked (fuses, bulbs, etc)? Do any of the lights work (high beams, parking lights, interior lights, etc.)? Please provide as much information as you can.
-Rod
Old Oct 31, 2012 | 04:04 PM
Ranger Louie
Nothing works interior or exterior, don't know where the lights fuse is located.Bulbs seem good.
Thanks
Old Nov 1, 2012 | 02:28 PM
87 XLT's Avatar
87 XLT
I dont have diagrams for a 93, but on most Fords "flash to pass" is wired from the fuse directly to the dimmer switch. See if "flash to pass" works.
If flash to pass does'nt work you need to check the fuse. If it does work the headlight switch on the dash is probably shot.
Old Nov 2, 2012 | 07:01 AM
shorod's Avatar
shorod
Trying the flash to pass is a good idea. I finally dug out my 1993 service manual and confirmed that the flash to pass uses a separate switch pole inside the multifunction switch to provide power from fuse F3 (60A) through a circuit breaker to the headlights. During normal headlight operation (high and low beam) power comes from fuse F2 (40A). Also, there is a 22A circuit breaker internal to the headlight switch, which if it failed, would prevent the headlights from working, but should not impact the parking and interior lights. However, if fuse F2 (40A) were to open, it would prevent both headlights, parking lights, and interior lights from working. The flash to pass feature would still work though. Both fuses F2 and F3 are located in the Power Distribution Box.
Have you also tried the brake lights, and do they work? The brake lights use the same filaments in the rear as the turn signals. The turn signals and brake lights are on separate fuses from the headlights and parking lights as well. If the lights not working are a single fuse issue, it will be one of the high current fuses in the power distribution box.
-Rod
Old Nov 2, 2012 | 01:41 PM
87 XLT's Avatar
87 XLT
Well there you go, check those fuses that Rod mentioned & see what you come up with.
I see this is wired the same as my 95 Taurus with a seperate fuse for the "flash to pass" feature.
powerstroke79
Nov 1, 2013 07:58 AM
Yougotthehit
Dec 27, 2009 07:42 PM
76CamperSpecial
May 20, 2008 09:31 PM
Chevythunder7578
Aug 1, 2004 08:27 PM
Chris89lx
Jun 22, 2004 10:55 PM
