mpg/compass display stopped working
Old Oct 29, 2012 | 10:48 PM
kgriffin's Avatar
kgriffin
Anybody have this issue and or know what could be the solution?
Old Oct 29, 2012 | 11:19 PM
AMG-SM's Avatar
AMG-SM
fuse maybe?
Old Oct 30, 2012 | 08:27 AM
jh818's Avatar
jh818
There are threads in here that could explain your problem. Some microchips may have broken loose and you may need to re-solder them back on.
Old Oct 30, 2012 | 10:16 AM
rla2005's Avatar
rla2005
Good info in here: https://www.ford-trucks.com/forums/4...-gone-out.html
Old Oct 30, 2012 | 11:47 AM
kgriffin's Avatar
kgriffin
Thanks guys, that thread is exactly what I need. Guess I should have done a little bit more searching before I started asking.
Old Oct 30, 2012 | 05:46 PM
rla2005's Avatar
rla2005
Anytime
Old Oct 31, 2012 | 07:20 PM
rsplash40's Avatar
rsplash40
yah! that rocked, I have a different console with only 4 clips holding it on, 3 screws to get the display out, soldered 3 chips back down and bammo! She's back, all nice and bright now too. No more than 30 minutes in and out.
Old Oct 31, 2012 | 09:22 PM
cooperfamily's Avatar
cooperfamily
Did mine for the second time yesterday. This time I drilled some holes in the plastic cover on both sides to hopefully keep it a little cooler.
Old Oct 31, 2012 | 09:59 PM
Forest's Avatar
Forest
Mine quit, but it turned out to be only a loose wire connector. Take it down and look at it...
4realestate
Mar 28, 2012 09:20 PM
RobertJohn
Feb 21, 2006 01:12 PM
Ford10
Mar 21, 2005 10:39 PM
ewellman
Jul 31, 2003 02:17 PM
RMbros
1978 - 1996 Big Bronco
Jul 10, 2003 02:20 PM
