Pick up bed interchange
Old Oct 29, 2012 | 08:32 PM
Andrew James's Avatar
Andrew James
I have a single cab shortbed truck with dual tanks and I am looking to purchase a flareside bed off a extended cab truck. Will it fit and what do I do about the tanks? I have never even used my rear tank ever but will it matchup to the gas lid and I an just trash the side tank or what?
It is an hour away, so should I find a trailer or will it maybe fit in the current bed of my truck? Will three people, my girlfriend, friend and I be able to lift the bed easily enough?
Old Oct 30, 2012 | 01:39 AM
Andrew James
Any help guys?
Old Oct 30, 2012 | 03:28 AM
joshh's Avatar
joshh
as long as your truck isnt lowered you can make a bracket in the fenderwell to hold the filler neck might be a little harder to fill but is doable
Parts of the bed are the same width as the stock bed so no it wont fit inside i would suggest a trailer
Old Oct 30, 2012 | 07:48 AM
sticky58's Avatar
sticky58
the beds will interchange if both are short boxes, the big difference is in the filler necks, they are different but can be made to fit, the section at the door and the doors themselve are different the rear bumpers are way different and will not interchange,even the brackets are different,if you can`t get the bumper,you`ll need a roll-pan,the tailgates are also different.if you can find the running boards, they are a big help as the box sits lower than the can on a step side....hope this helps...
Old Oct 30, 2012 | 12:28 PM
khadma's Avatar
khadma
Carpenter Local 745
People have transported beds by flipping them over on to the transport truck.
Since your Flareside bed is too narrow you could support the bed upsidedown
on 4x4s.
A trailer is good too.
Puckersdaddy
Dec 30, 2017 09:26 PM
Anthony487
Nov 15, 2013 11:58 PM
jleal_21
Jul 6, 2013 07:21 PM
north east ford
Feb 24, 2004 10:19 AM
John Heffelfinger
Nov 1, 1999 02:45 PM
