Help!!!!!! New injectors, pull to crank then won't pull off!?!?!?!?!?
Old Oct 29, 2012 | 05:38 PM
BIGMAC91's Avatar
BIGMAC91
Brand new injectors, just in today, cranked it up, ran like a champ. Got down the road bout 5miles, and just died out. Now I have to pull it to crank and will idle just a tad rough but when I go to take off it goes a second but then just dies. I can't find any leaks around return lines or anything, Im in dire need of help, trucks on the side of the road, in the hurricane. Anything will be appreciated.
BIGMAC91
Old Oct 29, 2012 | 05:49 PM
therifleman556's Avatar
therifleman556
Any pinched fuel lines?
Was the injection pump off for the injector swap?
Injection pump timed after injectors in?
Age of the lift pump?
Need more info!
Old Oct 29, 2012 | 05:55 PM
BIGMAC91's Avatar
BIGMAC91
All fuel lines are fine, and the IP stayed on and in place during the work this a.m. No, I didn't check the timing, because it idled and ran smooth. But it only dies if it's under a load. It would idle forever, without dying out. It's blowing my mind.
Old Oct 29, 2012 | 06:00 PM
therifleman556
Hopefully someone else has got an idea of whats going on. All I can think of is either plugged fuel filter, plugged return line, or bad lift pump.
Old Oct 29, 2012 | 06:05 PM
therifleman556
on second though, GET A HOOK! If theres still time find a friend, neighbor, or anyone and drag it someplace safe...
BIGMAC91's Avatar
BIGMAC91
Alright man, thanks for trying.
Old Oct 29, 2012 | 06:18 PM
kobaltblue's Avatar
kobaltblue
Originally Posted by therifleman556
All I can think of is either plugged fuel filter, or bad lift pump.
^^^What he said^^^
25.00 and your good to go....Sucks your caught in the storm though.
Old Oct 29, 2012 | 06:22 PM
BIGMAC91's Avatar
BIGMAC91
Yeah man, I'll head to the napa in the a.m. And get a filter.
Old Oct 29, 2012 | 06:57 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yeah don't go messing with it now.pull her home until Sandy is gone!
Old Oct 29, 2012 | 07:01 PM
BIGMAC91's Avatar
BIGMAC91
Yeah, I got it to a pretty safe place now, so it'll be good til tomorrow.
Old Oct 29, 2012 | 07:19 PM
Onus's Avatar
Onus
The fuel lines a selector valve can get junk in them too but check your filter, and fuel pump first.
I ended up having that problem and bypassing the factory lines fixed my problem.
Old Oct 29, 2012 | 07:23 PM
kobaltblue's Avatar
kobaltblue
You may want to change the filter but its the lift pump thats most likely bad.
Old Oct 29, 2012 | 07:30 PM
therifleman556
^^^^ A filter is not likely to cause such a drastic and sudden power loss, but change it anyway and check the pump for sure
Old Oct 30, 2012 | 12:00 AM
Mikey Oldaker's Avatar
Mikey Oldaker
ya know i had something similar go wrong with mine turned out to be the ip was weak wouldnt want to get up and go and even climbing a small hill seemed to take lots of effort i would guess that its the ip but it could also be the lift pump. from the sounds of it you put new injectors in then my guess would be ip because your ip is probably getting worn and doesnt want to push that sort of pressure anymore
Old Oct 30, 2012 | 04:39 PM
BIGMAC91's Avatar
BIGMAC91
Alright guys, I put on a new fuel filter and and checked everything y'all said, but I had already done away with the mechanical lift pump and installed an electric unit on the frame. The truck made it home, white smoke rolling, and little to no power, could it be that the electric pump is not putting out enough or something in the IP?
Thanks for you guys help, I appreciate it.
