Sponsored by: Real Truck
Leaking Oil Pan
Old Oct 29, 2012 | 10:24 AM
LoveDDs's Avatar
LoveDDs
Leaking Oil Pan
I have 2 small pin holes in the oil pan in my 2000 F350. Its a brand new oil pan installed within the year so its not from rust. I dont know how they got there since its fairly high up.
I dont want to replace the pan because i dont have the money to get some one to do it or the experience to do it my self.
Ive read at different forms a couple solutions...
1. JpWeld. (Sand to bare metal, lean super well and apply a couple coatings.)
2. Patch weld
3. Plumbers epoxy putty
4. Put self tapping/ mechanic screws in the whole then cover with JP weld
Im leaning towards the JP weld. I know its not a permanent fix but at this rate I am probably going to sell the thing anyways. To many problems
Old Oct 29, 2012 | 10:58 AM
Tom's Avatar
Tom
Sorry to hear about your troubles, did the shop who installed the pan have any kind of warranty? Which engine do you have in this truck?
Old Oct 29, 2012 | 11:54 AM
LoveDDs's Avatar
LoveDDs
no warranty since the guy i bought it offs friend (whos a mechanic) did it. 7.3 diesel
Old Oct 29, 2012 | 12:09 PM
EXv10's Avatar
EXv10
2. Patch weld
Go with #4 and JB otherwise you will have to drop the pan and clean it out. Even with #4 you will have to drain the pan and let it sit overnight to insure there's no oil at the hole location, but go it one better by; sanding the area, putting JB on the panhead screw, screw it in, let it sit overnight, rough it up, then apply more jb on top of it, and yes that would be a permanent fix.
Old Oct 29, 2012 | 12:51 PM
LoveDDs's Avatar
LoveDDs
After talking to my mechanic he seemed skeptical about #4 since it could make the hole bigger if its not in perfectly as well as how high up it is on the pan could make it difficult to get it in straight (a screw on a angle wouldnt work) I am going to try #1. See how long that lasts. If that pops out ill do number 4# and if that fails well guess ill be taking the engine out. To bad they made it so inconvenient to change this part. Seems to be a common and yet expensive repair
Old Oct 29, 2012 | 01:00 PM
EXv10's Avatar
EXv10
No! Do #4 and use small panhead self tapping screws. Of of course the hole will get a little bigger. I was a mechanic too and have done lots of this stuff.
Old Oct 29, 2012 | 01:04 PM
LoveDDs's Avatar
LoveDDs
Ok guess ill try it out. SHould i put JB first and then put the screws then more jb weld? Or just screws the Jb weld.
Ive never done an oil change so do i just undo the screw drain the oil do the repair then fill the oil back up checking the stick (check cold first, then turn engine on and repeat) as I add the oil.
Old Oct 29, 2012 | 01:51 PM
EXv10's Avatar
EXv10
>Get an engine de-greaser spray can, spray the pan and then hit it with the quarter car wash sprayer or garden hose if need be.
>Drain the oil and preferably let it sit overnight.
>Clean and sand or rough up with a file where the hole is.
>Get some small panhead self-tapping screws and put some JB Weld on the thread and under side of head.
>Screw it in (you might need a short screwdriver or right angle drill with a bit, or have to remove parts).
>Rough it up again and smooth some JB over the top of the head.
>Let it sit for whatever is says on the JB tube.
>Refill the pan............done.
Old Oct 29, 2012 | 02:07 PM
LoveDDs's Avatar
LoveDDs
Thanks EX! Would brake cleaner work as the de greaser? I here this is stronger then acetone
Old Oct 29, 2012 | 02:44 PM
EXv10's Avatar
EXv10
Yea, whatever cuts the grease, then hose it down so you can see what you are doing. If you can't find the self tapping small pan-head screws you can use machine pan-heads but you might have to drill also with those. You might have to rent a right angle drill with a new phillips bit also.
Raymond
18
Dec 8, 2011 07:59 PM
powerstroke1869
Jun 3, 2010 04:55 PM
bluerage
Jan 9, 2007 08:46 PM
fordv840
Dec 2, 2005 01:27 PM
covrace
Nov 17, 2003 05:00 PM
