supercharge me
Old Oct 29, 2012 | 02:11 AM
diesel-kid's Avatar
diesel-kid
supercharge me
Does anyone make a supercharger kit or turbo kit for our trucks? I have a 96 f150 4x4 with a 302 and an e4od auto, i'm gonna be doing an intake and exhaust and probably a programmer or chip but I know I'll want more power, I'd love to turbo it or supercharge it but I can't find any kits online for these things
Old Oct 29, 2012 | 04:33 AM
Andrew James's Avatar
Andrew James
Look at 302 Mustang stuff. A stroker 351w would be a fairly easy way for power.
Old Oct 29, 2012 | 12:04 PM
Freightrain's Avatar
Freightrain
I had a Vortech supercharger on my then new '96 F350/460. Was really cool and really woke that big truck up.
Vortech doesn't really list anything for these trucks anymore. Might be able to retrofit a Mustang set up?
1986-1993 Ford Mustang 5.0L Supercharging Systems | Vortech Superchargers
I wonder if maybe a phone call to them might find they have some spare parts laying around to mount it to a truck motor? Like the air intake pipes?
I'd love to have one on my '89 F150 302.
Old Oct 29, 2012 | 03:31 PM
pfogle's Avatar
pfogle
The problem is that that you would need more than just the super. That truck is speed density (OBD-I) and will require a custom computer program to run properly with a supercharger. If it was a little newer (or you convert it to MAF) then it be much easier.
Old Oct 29, 2012 | 09:23 PM
blkF250HD's Avatar
blkF250HD
Yup, custom tune is in order for that route. 2-bar MAP sensor, larger injectors, upgraded fuel pumps, wastegate control (for a turbo), etc. Turbocharging is possible with a speed density system (The GMC Syclone & Typhoon are SD), however it's much more limited than a MAF system.
Old Nov 13, 2012 | 05:18 PM
strokin'_tatsch's Avatar
strokin'_tatsch
***BUMP***
Does anyone know if a centrifugal supercharger like a Vortech or Procharger setup for a fox Mustang can be fitted to a truck without too much modification to the kit itself? Down the road I want to add a supercharger or turbo(s) to my 5.0 and trying to sort out my options. Would like to see around 450hp. I've been trying to find a used Vortech kit for the trucks, but no luck. They are hard to come by and the couple that I have come across need head unit rebuilds and/or most of the kit is destroyed. I would prefer to use new parts anyways.
Old Nov 13, 2012 | 07:58 PM
kas83's Avatar
kas83
I can't see why a Mustang setup couldn't be adapted, since a common MAF swap for the trucks is to use Mustang components. With the truck being a 96, it should already be MAF anyways, I thought.
Old Nov 14, 2012 | 09:36 AM
5thanddown's Avatar
5thanddown
For what a supercharger kit runs you might just be better off starting out with a bigger engin. What did the vortech do to your mpg's???
Old Nov 14, 2012 | 10:46 AM
Freightrain
Back in '97, fuel mileage wasn't a concern . Gas was only a $1/gal.
Truck got a solid 10 mpg daily driving to work. Since I didn't really flog on it constanly, I can't recall mileage getting much worse.
As for the cost of the kit? I got it discounted, through a friend that worked at Summit Racing back in the day. I had the cash and bought it. The truck pulled my 40ft trailer without too much issue anyway, but the blower was too cool to pass up. The 460 was the "big" motor for the day. Things were quite different 15 yrs ago!
Old Nov 14, 2012 | 11:29 AM
5thanddown's Avatar
5thanddown
That is true. I drive a 95 crew 460 5 speed and put a good 25000 miles a year on it. my mpgs range anywhere from 7 towing to 11 hwy so i'm liking the sounds of a supercharger that would really help on those long hills here in mt, with 17000 pounds of cattle on back.
Old Nov 14, 2012 | 12:40 PM
strokin'_tatsch
Originally Posted by strokin'_tatsch
***BUMP***
I guess what I was trying to ask here was if anyone knew how much modification would have to be made to the brackets for the SC if a kit for a mustang was used. I found a couple pics last night that make it look like it can be made to work.. Just don't want to drop so much money to not be able to use it. LOL The ones that look like they would be easier to make work mount on the driver side. The passenger side truck accessories appear to be different, more so than the driver side anyways.. Heck I don't know.. I need to look at it in person.
Driver side mounted '86-93:
Passenger side mounted '86-93:
Driver side mounted '94-95 Stang:
Passenger side mounted '94-95:
Old Nov 14, 2012 | 03:19 PM
NLPRacing's Avatar
NLPRacing
I can't speak for the OP's truck, but my 95 F150 5.0 has MAF as did my old 96 F150 5.8.
Old Nov 14, 2012 | 03:26 PM
pfogle's Avatar
pfogle
In '96 it should be MAF. In '95 only the California models were MAF.
Fl407
Apr 7, 2016 08:47 AM
buzzy613
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 20, 2013 08:04 PM
LoxBoy
Sep 16, 2008 08:27 AM
78F150XLT
37
Jan 29, 2008 01:05 PM
dnchevyman
Oct 31, 2005 09:13 AM
