I can't stand drive in winter when it barely blow heat to window to defrost.
I check voltage to blower it 14.78 volt while engine running. LO-HI are same volt I know bad resistor but blower supposed to be blow STRONG but now it blow like it was LO I don't think it worn out blower. If it was worn it wouldn't turn.
I check blend door where you can see blower spin it open/close fine.
On other thing I notice randomly with Heat/cold control there were little jump like there resistance on **** but half way middle no resistance on it.
Its the fan, I had this happen with a over the counter cheap one from the auto parts store. I went and got a used one from the junk yard that was factory and it fixed the slow motor problem.
