Dumbest Question Ever Thread
Old Oct 28, 2012 | 06:15 PM
richdawg's Avatar
richdawg
Just getting ready to pull the shifter off so I can put 4 qts of redline in, I got one bolt left and thought I better ask now before I take it out. Should the shifter be in any special gear when I pull it out?
Old Oct 28, 2012 | 06:35 PM
ReBilld's Avatar
ReBilld
I don't think it matters Rich, but I leave mine in nuetral.
Old Oct 28, 2012 | 06:51 PM
96ford250's Avatar
96ford250
Neutral would be the easiest to line up when your putting it bak it
Old Oct 28, 2012 | 07:02 PM
redman84's Avatar
redman84
Report back on the redline. I'm going w it or amsoil next change. Which redline are you using?
Old Oct 28, 2012 | 07:23 PM
richdawg's Avatar
richdawg
Neutral is what I was going to do but thought I would ask, thanks guys
This is the stuff I'm using, I'll let you know how it works out.
Old Oct 28, 2012 | 07:53 PM
ReBilld's Avatar
ReBilld
Is your gear rollover bad Rich? Mine is, I'm thinking about putting a bottle of the Lucas auto trans stuff in it to see if it will quiet it down some.
Old Oct 28, 2012 | 08:15 PM
richdawg's Avatar
richdawg
I can live with the rollover its way better than it was. I have had this truck for 6 years my first PSD, and have not changed the fluid in the trans. The p o had most of the service done at the ford dealer, so was maintained pretty well. The problem I would like to go away is the difficultly I have getting it to go in gear when stopped and needing to shift to first or reverse, I don't really think this is the problem but I can always hope it gets a little better.
Old Oct 28, 2012 | 08:20 PM
richdawg's Avatar
richdawg
I can't think of any reason not to try the Lucas, just remember to take a quart out if your still running 5. I've heard a lot of people like that Lucas but thats mostly from what I have read on FTE so you know that too. Don't ask Glenn though
Old Oct 28, 2012 | 08:23 PM
ReBilld's Avatar
ReBilld
You did the heim joint on the clutch master cylinder rod didn't you?
Old Oct 28, 2012 | 08:55 PM
richdawg's Avatar
richdawg
Ya, I did the heim a little over 2 years ago. I think the clutch is disengaging good and it engages at a little over half peddle letting it out.
Old Oct 28, 2012 | 09:20 PM
Talyn's Avatar
Talyn
Its best to pull it in neutral, but if you accidently pull it in gear, you can pop it into neutral with a screw driver.
Old Oct 28, 2012 | 11:10 PM
oldbird1965's Avatar
oldbird1965
Apples and oranges buddy, good luck!
Old Oct 29, 2012 | 02:27 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Disappointed. Far far far from the dumbest question ever. Not even in the top 50.....
Old Oct 29, 2012 | 02:30 PM
oldbird1965
Ya, you can do better then that Rich, LOL
Old Oct 30, 2012 | 04:11 AM
richdawg's Avatar
richdawg
I put 4 1/2 quarts of the redline in and put the shifter back on. I didn't tighten the bellows cover down but put it in place. I drove it about 20 miles, it did seem a little quieter and the shifting seemed a little better too. The jury is still out on this though I did notice that when the shifter cover bellows thing was lifted up a little when just at idle it got a lot louder, I'm thinking about stuffing some kind of insulation or sound deadening material in that cover before I tighten it down. I won't be able to work on it for a couple of days though because I got grounded, can't go outside for 2 days
