I had some questions on my old injectors and thought it would be a great topic for open discussion. These engines are reaching "that age" and the stick shops are getting a big backlog on work. I see plenty of people talking about injectors, so maybe those of us who have taken the "plunger" can share our pictures and discuss what we found in there. I'm sure there are plenty of pix because few would throw this much ante on the table and not commemorate it with a click.
Stinky's history: Injectors 3 and 7 gave me grief a year ago and they were replaced by remans (before FTE input) at 240K. I then learned I had every kind of exhaust leak known in the automotive industry. The exhaust leaks were fixed a year ago, but a boost leak is new... maybe a month before my recent total stick swap (260K), maybe at the swap (installing 38R at the same time could have introduced it). I typically used the 60e tune and the stock tune, with a bump to 80e when I needed to pass on a two-lane road and Decel tune on steep grades. I haven't towed my boat this summer. What am I seeing here that I haven't seen on other injector pictures recently posted?
I only really see one question unless you are asking as well what the plunger's a barrels, or pintle look like, and you would need to start by taking them apart. Most of the injector issues, are going to be internal i.e. poppet seat wear, internal orings, etc.
As for the "what am I seeing" portion, are you referring to the rough almost knurled surface of the fuel inlet portion, surrounding the plunger?
I had to get my old ones back to FFD, so no disassembly for me. I was looking at the color of the barrels (I think that's what they're called) on the original injectors and the debris on the nozzles. #8 is clean, but #1 (on the other dead end) is as dark as #2 (first for fuel on the driver side). The 6-8 firing order at play here? Temperature differentials? What is that diagonal ring... a fluid sitting when parked?
I plead dumber than a box-o-rocks here and I welcome the basics. I'm sure other readers will appreciate this as well.
As for the WVO/B100 pictures - is that the "coking" that the injector shops refer to when they say that can void warranties and deposit refunds?
The discoloration is just the injector cap, that portion actually will thread off, all the way up to the fuel inlets. The barrel is internal as well. I've got a exploded diagram somewhere I'll locate.
I can only speculate on variations, but heat has to play a factor, as well as the "lines" there could be some combustion gases that come into play as well.
That being said, they look like nearly all injectors I have pulled.
I believe the discoloration is due to combustion gas leaking past the copper washer. When I re-ringed my injectors there were 3 that looked like that, and all 3 had slightly loose hold down bolts.
Wouldn't that send hot gasses past the lower O-ring and into the fuel line? I can theorize the leak was small enough so as not to create the scenario I just described. I'm really throwing feces at the wall here... just to see what sticks.
Excellent basic science question. I would appreciate it if Mr. Rosewood or the other injector sponsors could chime in on this thread.
These are mine from the driver's side. In this picture I have already used emory cloth on the nozzles to clean them up before inspecting the nozzles for cracks with a stereoscope. They didn't have many deposits on them prior to clean up, but I screwed up the crime scene by not photographing before the cleanup. There were no cracks anywhere including between injector nozzle holes. Some of the holes did appear to be "clogged" more than others though.
CSIPSD said that a nozzle cannot "stick open." I believe that my white smoke is coming from unburnt fuel in the cylinder caused by overheating caused by a fuel starvation problem due to clogged in-fuel-tank pickup/mixing screens. I don't see any channels running through the o-rings so (assuming it is an inector mechanical problem and is not an electrical problem -- hopefully I will know next week) the introduction of the extra fuel would have to be internal, wouldn't it?
Comparing all these injectors with mine, I really wonder what that discoloration is on my caps.
Most likely from fuel/oil that was in there at assembly or leaked past the lower o-ring in the course of their lifetime. This area should be 'dry' by design, but even a small amount of fuel/oil trapped in there could easily cause the discoloration.
The 'debris' on tips is normal. 'Coking' is a thick, crusty build-up that does not wipe off easily.
This is what combustion gasses leaking past the copper gasket looks like...
