01 E350 wipers dont work
Old Oct 28, 2012 | 12:54 AM
YellowGTO's Avatar
YellowGTO
Hey guys, Ive replaced the motor, and the cable has a hot line but I cant get the wipers to move. I've been trying to hunt the relay down but I just cant find it. Any help would be appreciated thanks
Old Oct 28, 2012 | 03:41 AM
kell104's Avatar
kell104
First I would start by checking ALL your fuses, in the dash, and under the hood. It is best to check them with a test light as ocationally they can "look" good but be blown.
The relay(s) are in the big fusebox under the hood behind the air filter housing. There are actually two relays according to the manual for my 01. One for hi/low and one for park/run. (position #34,35 if it is the same for your 02) It has been my experience on ford vehicles that more often than not it is the so called multifunction switch on the column. It is actually the whole lever for turn signals, wipe/wash, and hazard flashers. Not to say that is the only possibility but I have replaced four of them in different vehicles across 10 years of ford production and they all did the same thing at the end. The wipers would cut in and out in all positions from intermittent, low and Hi. Then after some time they just stopped working completely. I don't really know a way to test for it. They are not really expensive (I think the last one was about 60$) and if everything else checks out it is a place to look.
Old Oct 28, 2012 | 11:25 AM
YellowGTO's Avatar
YellowGTO
Thanks, I just wanted to swap it with other relays just to check it off thu list. I actually have a new lever on the way. I will pickup a tester for the fuses I just did a visual last time.
Old Oct 28, 2012 | 11:55 AM
kell104's Avatar
kell104
Sorry, I could have sworn I saw you had an 02. Do you have the owners manual still or not? I have the PDF version so I can try to copy the pages about relays in and post them if you want.
Old Oct 28, 2012 | 01:01 PM
YellowGTO's Avatar
YellowGTO
That would be great. It dint come with an owner manual when I bought it :P
Old Oct 28, 2012 | 01:32 PM
kell104's Avatar
kell104
well, here is what i have got. It is for an F-series so I hope it helps.
Old Oct 28, 2012 | 09:32 PM
YellowGTO's Avatar
YellowGTO
Thanks for your hardwork but it seems the E350s fuse box is setup different. I did find it though but it seems like only 1 fuse for the wipers. Surely there has to be relay no?
1999 ford e350 fuse panel diagram - JustAnswer
Old Oct 28, 2012 | 10:02 PM
kell104's Avatar
kell104
Sorry it couldn't help. There must be a relay someplace. Good luck.
Old Oct 28, 2012 | 10:03 PM
YellowGTO's Avatar
YellowGTO
If anyone could confirm it, it looks like this is the part. I guess after this damn hurricane ill just pull it and read the P/N. If the bus still exists after the hurricane lol
Old Oct 28, 2012 | 10:57 PM
kell104's Avatar
kell104
Looks like you have a "wiper control module". Maybe that takes the place of the relay???
Old Nov 1, 2012 | 03:15 PM
YellowGTO's Avatar
YellowGTO
Yeah new lever came in no luck . Now yc2t-17d539-aa seems to be the part number on the side but I ordered one from a 1996 E150 they look exactly the same and its 130 cheaper
Old Nov 2, 2012 | 07:42 PM
1fixitman's Avatar
1fixitman
130 cheaper. Holy smokes batman. If it is 130 cheaper then how much is the whole module?
Old Nov 11, 2012 | 04:21 PM
YellowGTO's Avatar
YellowGTO
Its 150 for the module. I found one on Ebay for a 97 for 20 bucks. Well the part came in and it was bigger PLUS the plug didn't fit so I was like F that im going to take it into the dealer and let them do it. Then I got to thinking what if I just make the plug fit into the old one and BAM! wipers work :P
Well its only 1 speed on or off but it works so if you want a cheap fix I hope this save someone some money.
Old Nov 11, 2012 | 11:36 PM
kell104's Avatar
kell104
Glad to hear it is working. I am suprised they use such a different system on the vans. I guess they do it for their own reasons. Maybe at some point you can find the correct piece and get your delay wipers back.
Old Nov 13, 2012 | 02:37 PM
YellowGTO's Avatar
YellowGTO
Yeah, I will probably buy the correct part just sucks how expensive but I know what the problem is now at least.
