1978 - 1996 Big Bronco
Rough Acceleration
Old May 20, 2003 | 10:49 AM
buckeyebronco's Avatar
buckeyebronco
Rough Acceleration
Just ten minutes ago on my way to class I was accelerating somewhat slowly and at about 20-25 mph the truck started to lurch then hesitate and lurch and so on until i got to about 28-30 mph then again at about 32-35 mph. I drove it a bit longer to see if it would continue and it slowly faded away the more times I accelerated. I just had my aod trans rebuilt less than a month ago. can anybody help me out?
Old May 20, 2003 | 10:28 PM
steve83's Avatar
steve83
Rough Acceleration
Pull the codes.
Old May 21, 2003 | 12:01 PM
buckeyebronco
Rough Acceleration
I don't have any lights coming on and I dont have a computer for that or the money to pay somebody to do it.
Old May 21, 2003 | 12:22 PM
mrwizard's Avatar
mrwizard
Rough Acceleration
You don't need a computer. Did you go to the link Steve posted? All you need is a piece of wire or a paperclip (and a piece of paper and pencil to write down the codes).
Old May 21, 2003 | 05:15 PM
buckeyebronco
Rough Acceleration
Wow thats alot of info it may take me a while to let you guys know if i got it to work. If I mess up can I really mess up my truck and if I do mess up how do I fix it?
Old May 21, 2003 | 09:45 PM
steve83's Avatar
steve83
Rough Acceleration
You can't hurt it unless you ground or short something, so go for it - Ford computers are tough. Basically, warm up the engine, turn it off, put in the jumper wire, turn the key to RUN, and watch the engine light (CEL or MIL).
Old May 25, 2003 | 08:50 PM
mikefraz01's Avatar
mikefraz01
Rough Acceleration
im having the exact same problem, but have yet to pull the codes because the ses light never came on, it happened after i had a new 4.9 installed, and after i had a problem with the eec relay and fuel pump relay wich turned out to be a harness problem, i feel a connection here.... either the harness is whacked or i need a new mechanic, ill let ya know what happens when i get the codes
Old May 25, 2003 | 09:12 PM
AbadDriver's Avatar
AbadDriver
Rough Acceleration
auto zone pulls codes for free. jsut a sugestion......BTW for auto zone to pull codes i need to know where to hook it up on mine. 92 5.8 . Thx
Tim
Old May 26, 2003 | 12:21 AM
steve83's Avatar
steve83
Rough Acceleration
Look at my code list page - it shows the connector. It's near the L hood hinge inside a black cover that says "EEC TEST".
Old May 26, 2003 | 07:17 AM
AbadDriver's Avatar
AbadDriver
Rough Acceleration
yeah... i saw that but the conection they had was different, so should i jusat buy buy one of the $30 code readers?
Tim
Old May 26, 2003 | 01:26 PM
mikefraz01's Avatar
mikefraz01
Rough Acceleration
save your money, the codes will flash out on your check engine light when you run a jump wire to the eec test, with a voltometer
jgoedker
Jan 2, 2014 07:55 PM
RickPlmr
Oct 14, 2005 07:23 PM
herunar
Apr 28, 2002 10:04 PM
