fuse pannel
Old Oct 26, 2012 | 02:12 PM
Talyn's Avatar
Talyn
fuse pannel
Hey, i'm looking for a fuse pannel for our trucks if anyone has one.
When I had a no brain moment a couple months back I tried to hook my batteries up backwards. Luckily it just touched for a second, but I dicked up my heater fuse block, the surge all went there thankfully, but its burnt up pretty bad and looks like i'm getting a lot of resistance on the terminal.
So I need to replace it.
Old Oct 26, 2012 | 02:16 PM
DIYMechanic's Avatar
DIYMechanic
This is the interior fuse panel, correct?
Old Oct 27, 2012 | 10:32 AM
Talyn's Avatar
Talyn
You betcha.
I thought I saved the one from my f-150, but I was sadly mistaken.
Nice thing is, I might hard wire in fuses for my gauges though when I replace this thing.
I have no heater controls right now.
I'm glad my scangauge peedered out on me cause i wouldn't have checked the pannel.
It was melted pretty bad.
ON a side note on that, my cigarette lighter stopped working too, I think they are connected.
Old Oct 27, 2012 | 12:35 PM
tjc transport's Avatar
tjc transport
i ain't rite
on my 88 the wiring to the heater circuit was bad from the factory. after around 10 years, i was down to around 6 or 7 strands of wire . i cut the wire out and replaced that circuit with a 50 amp maxi fuse harness with a 25 amp fuse in it.
no problems out of it since then.
when i cut the wire out of the fuse block i found out it supplied the heat/AC, brake light, blinkers, and lighter.
Old Oct 27, 2012 | 12:40 PM
Talyn's Avatar
Talyn
Alright, I'm betting that is my issue then.
Thanks for that info.
I don't want to really get into it today though.
I'll have to figure it out when I pull the block when I have a replacement.
Old Oct 27, 2012 | 08:00 PM
DIYMechanic
I am pretty sure I have one in the gray dash from the last truck I scrapped. What exactly do you need? The whole dash harness or just the block?
Old Oct 27, 2012 | 09:16 PM
Talyn's Avatar
Talyn
Just the block.
I got a video. gimmie a few to post it.
Old Oct 27, 2012 | 09:46 PM
Talyn's Avatar
Talyn
Burnt Fuse Terminal - YouTube
here ya all go. check the damage. =*(
Old Oct 27, 2012 | 09:57 PM
ReBilld's Avatar
ReBilld
I've got a couple fuse blocks William. Do you still need one?
Old Oct 27, 2012 | 10:12 PM
Talyn's Avatar
Talyn
Well, I'm hoping somebody will send me one. =)
Old Oct 27, 2012 | 10:19 PM
ReBilld's Avatar
ReBilld
PM me an address and I'll pull one tomorrow and send it out Monday.
Old Oct 27, 2012 | 10:27 PM
fordman67's Avatar
fordman67
Or i can run to the u pull tomorrow.there are several trucks out there.AND I CAN BE MORE BRUTAL since it does not matter.
Old Oct 27, 2012 | 10:37 PM
Talyn's Avatar
Talyn
I'll text it to ya Bill. I think I still have your number.
Old Oct 27, 2012 | 10:40 PM
Talyn's Avatar
Talyn
Okay, I'm not sure what I did with your number.
WTF is with that? I've texted with you a lot too.
Old Oct 27, 2012 | 10:46 PM
ReBilld's Avatar
ReBilld
I just tried to call you and got your voicemail.
