Fuel Selector Valve
PO had installed a manual style valve that I just wasn't crazy about. It was installed crooked, stops in 4 spots, but only has labels in 3 corners.
Tonight while looking at my truck after doing some reading I turned the key and heard the magical noise of a solenoid clicking! Sure enough the solenoid is clicking on/off as I turn the key on/off and when I flip the instrument cluster fuel gauge selector switch between main and Aux. The fuel gauge is not picking up the fuel level for the main tank, but that's not a big worry. The wiring on the main tank sending unit is corroded and loose so it'll probably start working when I clean that all up. I'm happy that I am able to use the dash switch and no longer need the manual valve. Sort of... now I just need to clean out the clogged main line/tank. When I put a new inline fuel filter on a few weeks back, the inline filter from PO had a fine collection of red desert dust in it. I bypassed the main line and directly hooked up the Aux. line.
Once I clean out the main line I can hook up both lines to the fuel selector valve. Main and Aux lines each have their own clear inline filter so I can see if any more problems are to be expected.
Just had to share my little triumph
The switch (D3TZ-9A050-A) only changes the dash fuel gauge from one tank to the other.
1975/79 F100/350's with dual tanks came with: D5TZ-9189-B .. Fuel Tank Selector Valve & Solenoid Assy. Located on frame rail.
The switch (D5TZ-9A050-A) changes the tanks and the fuel gauge.
1973/79 F100/350 with factory installed dual fuel tanks: The switch is located in the heater control panel.
D1AZ-9A011-A .. Plastic Mesh Filter Screen-3/8" I.D. / Slips onto fuel sending units pickup tube / Available from Ford/autoparts stores.
All 1964/79 FoMoCo vehicles except Maverick/Comet/Pinto/Bobcat (use D1FZ-9A011-A 5/16" I.D.).
I can turn the key with one hand while reaching under the cab with the other hand and feel the solenoid working. It's a very distinct clunking sound.
