fuel tank selector
Old Dec 18, 2011 | 08:02 PM
400 .040over's Avatar
400 .040over
fuel tank selector
can't find a fuel tank selector switch for a 79 f-250 w/twin tanks
Old Dec 18, 2011 | 08:13 PM
frty7ford's Avatar
frty7ford
there were two options that i can think of mechanical drivers side floor board and electric to the right of the heater controls in the same pannel
Old Dec 18, 2011 | 08:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ-9A050-A .. Fuel Tank Selector Switch / Marked: D5TB-9A050-AA / Available from Ford, the Memphis TN FoMoCo parts depot has 68 of the little charmers.
There are dozens more at dealers all across the US. If your local PA dealer doesn't have it, it takes only a coupla days to get it.
Edit: At least two dealers in PA have it in stock / Manderbach Ford in Temple PA has ONE (610-929-3683) / Fred Beans in Doylestown PA has ONE (215-348-0202). There may be others.
Mounts in heater control panel / Also switches the dash fuel gauge from one tank to the other.
Applications: 1975/86 F100/350 / MSRP: $31.51.
Originally Posted by frty7ford
There were two options I can think of...
The OP has a 1979.
ALL 1975/79 F100/350's with dual tanks have this: D5TZ-9189-B (replaced D5TZ-9189-A & D8TZ-9189-A) .. Fuel Tank Selector Valve & Solenoid Assy / Marked: D5TB-9F271-AA or D8TB-9F271-AA or D9TB-9F271-AA
Since this valve is electric, when the switch is activated, it switches the tanks and the fuel gauge.
1973/74 F100/350's with dual tanks have a manually operated selector valve mounted on the floor, adjacent to the drivers side of the seat.
The switch (D3TZ-9A050-A) used with this valve only switches the dash fuel gauge, so it's not the same switch as 1975/79 (1975/86).
Old Jan 1, 2012 | 05:03 PM
RichardPerry's Avatar
RichardPerry
I have a 1973 F250 with both a rear and mid-ship tank. As mine has a manual valve, I am wondering if replacing with an electric valve is even an option, and how much work would be involved in doing so.
I hope this isn't considering hijacking...
Old Jan 1, 2012 | 08:40 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I don't know about a new one but if you want a used one, I can hook it up.
Vinford
33
Jan 3, 2019 02:40 PM
skapford
13
Aug 3, 2013 11:32 PM
brian1080
Apr 28, 2013 02:35 PM
maddogjohnson
Oct 26, 2012 10:29 AM
Myfreeford
Jul 5, 2011 01:20 PM
