Headlight
Old Oct 25, 2012 | 03:39 PM
dessmo's Avatar
dessmo
Headlight
Nothing happens when I turn the switch. I would be greatfull for any advise where to start searching for the solution.
Old Oct 25, 2012 | 06:14 PM
william_04_x's Avatar
william_04_x
Check your fuses first, then use a test light to go through the circuit(including relays). Your owners manual should have more specific info for fuse and relay identification. He has a MY 2K if someone has specific info to help him out.
Old Oct 26, 2012 | 02:10 AM
dessmo's Avatar
dessmo
I have used a test lamp, and the swirch seems to be OK. The car is set up with automatic driving lights which works. But when I try to turn on the parking light or driving light manually it does not work. The high hedalights will not stay on, but works as long as you "hold" the switch and the main switch is turned one. Where do I find the relays, anyone know?
Charles2703
1997 - 2003 F150
Jun 1, 2014 02:25 PM
MaxPayne
Electrical Systems/Wiring
Dec 13, 2013 12:54 PM
V10man
Oct 30, 2012 08:53 PM
FunkyPhat
Aerostar
Jan 12, 2009 03:28 PM
thbeast55
1997 - 2003 F150
Jul 20, 2003 11:27 PM
