Fuel Issues
Old Oct 25, 2012 | 10:09 AM
rlb42063's Avatar
rlb42063
Fuel Issues
Bought '87 F150 with a 4.9 swap. Pre-owner removed one of the gas tanks. Issue 1. Fuel gauge no longer works. Issue 2. Truck runs but every now and then, while driving, acts like running outa gas. Sometimes stops running all together. Let truck sit for awhile, will restart and run fine till it happens agian.
With all the wires and hoses still on truck from removed tank. will this cause most of all my problems? and where do i start...to make this a single tank system.
Old Oct 26, 2012 | 08:14 AM
subford's Avatar
subford
Do you hear the frame fuel pump run when you turn the key off and back on after it dies?
If not you may have a bad frame fuel pump.
But you would need to check the power to it to make sure it is getting power when it does not run.
zebraz
17
Dec 9, 2011 02:42 PM
Nick19894X4
May 13, 2007 06:12 PM
drewgarrett
Nov 14, 2005 09:39 PM
bigolford
Mar 8, 2005 04:23 PM
guitar333
Jul 12, 2004 12:41 AM
