Modular V10 (6.8l)
V-10 speedometer/ABS lite
Old Jun 9, 2003 | 07:07 PM
herb kent's Avatar
herb kent
Keith, The tech. did check out the new speed sensor and said it was ok. He said that the control unit also feeds the speedometer I ask if there was a way that you can bypass the ABS system but he did'nt know how or if it could be done. Because all trucks don't have ABS installed. I now have a query into Ford to see what can be done. Just don't have a spare $1000.00 to have them fix it when the truck only has 21000 miles on it. I'll keep you in the loop.
Old Jun 9, 2003 | 07:16 PM
nothingbutford's Avatar
nothingbutford
It seems that with only 21000 miles your vehicle should still be under warranty?
Old Jun 10, 2003 | 08:16 AM
herb kent's Avatar
herb kent
Not if you have had it over three years
Old Jun 16, 2003 | 04:49 PM
Fredvon4's Avatar
Fredvon4
Well if it is a reputable shop and you are satisfied that the ABS unit will do the trick then off to the junk yards for you. Many now have web search capability.
You will need to find out how many different vehicles and what years have the same or similar control unit.
Sorry to hear the diagnosis... getting close to the 36K point with this truck and only 24 months old...maybe I need to rethink my Ford ESP decision and reconsider the costs..
Old Jun 17, 2003 | 02:03 PM
cds72911's Avatar
cds72911
I had a 2002 F-250 SD CC and it had the ABS light issue and flashing OD light on the stalk. Mine turned out (after about 6 warranty visits) to be a ground wire.
The dealer service guy said they had a bulletin about it.
Charlie
woosterken
25
Mar 11, 2014 11:31 PM
shainsaw2002
Jun 23, 2011 07:58 PM
Kemicalburns
Jun 26, 2007 01:45 PM
t3lyons
1978 - 1996 Big Bronco
Jul 9, 2003 10:57 AM
