Fuel related question
Old Oct 24, 2012 | 07:00 PM
96ford250's Avatar
96ford250
My truck was originally gas and there was no switching valve on the rail like on a diesel but I've read other swaps and they said the diesel one bolted inplace of the gas one? How is this possible? It's got what looks like a little block then a split for the front tank and it continues to the rear thank that doesn't sound like the return would work correctly any one able to she'd any light on this? It worked fine when it was running. I wanted to reuse the lines cause the others were trashed and if I flushed them out they would be fine but this is a whole new problem.
Old Oct 24, 2012 | 07:50 PM
fordman67's Avatar
fordman67
Um.any dual tank truck has a switching valve.gas and diesel are completly different..
Old Oct 24, 2012 | 08:46 PM
96ford250's Avatar
96ford250
I know this but what I wanted to know was how they are switched in the gas trucks because there is no switching valve and they do it through the pumps themselves not through a splitting valve like the diesels do
Old Oct 24, 2012 | 10:57 PM
ReBilld's Avatar
ReBilld
On gas trucks, when you switch tanks, you are putting power from one pump to the other and it will only return gas to the tank it's pumping from. I think there are check valves in the return lines that are controlled by the pressure from the pump.
Old Oct 24, 2012 | 11:26 PM
96ford250's Avatar
96ford250
Yea they are in the pumps so that means custom lines here I come. Does anyone have a diagram for the valve in the diesel trucks like a tard I forgot to take a pic or make a diagram of how the lines are hooked up
Old Oct 24, 2012 | 11:53 PM
fordman67's Avatar
fordman67
How are you planning on eliminating the pumps from the tanks? Just remove and add a pick up?
Old Oct 25, 2012 | 10:26 AM
96ford250's Avatar
96ford250
I replaced them with the diesel pickups form the donor truck and I did an efuel
Old Oct 26, 2012 | 12:06 PM
96ford250's Avatar
96ford250
Does anyone know what the 3/8 fleetrite hose is rated at pressure wise?
Caveman Eric
Jan 7, 2018 12:53 PM
Yahiko
Sep 19, 2017 10:13 AM
Jheventhal
Nov 29, 2014 02:14 PM
Jaradtaylor43
16
Nov 18, 2013 12:35 PM
wreckinball
Feb 15, 2010 11:08 AM
