Sponsored by: Real Truck
2005 F250
Old Oct 24, 2012 | 02:52 PM
Marie Ellen Briones's Avatar
Marie Ellen Briones
2005 F250
The clock and radio on my truck is dead. I'm thinking it's a fuse. I don't have the owners manual anymore and looked one up online, but two diagrams were given. It shows relay 11 and/or 32. Any suggestions??
Old Oct 24, 2012 | 05:45 PM
mikeismadness's Avatar
mikeismadness
Pull both fuses and see if either is bad.
Old Oct 25, 2012 | 10:51 AM
Beerstalker's Avatar
Beerstalker
Go here and click on Owner's Guides, and pick the one for your make/model.
http://www.motorcraftservice.com/vdi...d=&kevin=rules
I would have given you a direct link, but a lot of the times they don't work for some reason.
Looking there it does look like 11 and 32 are the two fuses labelled for the radio. I would start by checking those fuses first. If both of them are ok, you will have to start checking other ones because not all of them are labelled for everything that they actually provide power to. For example I once blew a fuse that caused me to lose power to my radio, and power windows. I checked the fuses for those and they were all still good. My cousin looked up the wiring schematic and figured out that another fuse was the one causing the problem. If I remember correctly it was fuse 35, which is labelled for the instrument cluster, but my instrument cluster was working fine. So I would suggest maybe checking it too. If none of those are it, then I guess I would just start at fuse #1 and check through all of them.
crazyjerry
Electrical Systems/Wiring
Feb 1, 2019 08:56 AM
Bigb6.0
Nov 29, 2017 09:56 PM
sailan
Apr 14, 2011 12:22 AM
Dutch Oven Man
Sep 24, 2009 05:17 AM
Daddy*O
1997 - 2003 F150
Apr 15, 2005 04:09 PM
