AC Compressor Clutch Replacement
Old Oct 24, 2012 | 08:27 AM
mudbug04's Avatar
mudbug04
I dont know if im just not good at research or what but simply put, i believe my ac compressor clutch pulley bearing is going out. Makes noise whether ac is on or off. If i change out the clutch and pulley will this fix the problem? and is there a step by step guide out there somewhere on how to do this job? Do i need to replace the magnet or coil and if so how do i do this? Please help me I need to order parts and i need to fix it today. Thanks guys!!!
Old Oct 24, 2012 | 08:48 AM
woodnthings's Avatar
woodnthings
Try this first!
SpringerPop's Compressor Clutch Air Gap
Old Oct 24, 2012 | 08:51 AM
mueckster's Avatar
mueckster
Here is a pdf from my Ford manual to give you an idea how it all goes together. Compressor Clutch Replacement.pdf You should be able to replace the pulley/bearing assembly and clutch shoe without any special tools, other than some snap ring pliers.
Old Oct 24, 2012 | 08:53 AM
mudbug04's Avatar
mudbug04
yessir ive already done that, air conditioner works great now, problem is the pulley has a little bit of slop in it and it needs to be replaced i just dont know how far to go with it. just the pulley? change out the whole clutch with the pulley while im goin in? the magnet too?? i cant find anything about that.. thanks
Old Oct 24, 2012 | 08:59 AM
mudbug04's Avatar
mudbug04
Thanks Roland! maybe you could answer me this though.. is there any need to replace the "field coil" if everything is working?
Old Oct 24, 2012 | 09:05 AM
mueckster's Avatar
mueckster
Since it may be difficult to remove, I'd leave it be. You can always change it later. You'll already know how.
Old Oct 24, 2012 | 11:36 AM
KelVarnson's Avatar
KelVarnson
Typically, coils either work, or they don't. If it's working, I wouldn't replace it, unless there's obvious signs of damage, like melted or burned areas.
Old Oct 26, 2012 | 01:58 AM
SpringerPop's Avatar
SpringerPop
What ^^^ Roland and Kel ^^^ said.
Pop
evan1242
Jun 19, 2015 09:03 PM
Nathan A Kidder
Modular V10 (6.8l)
Jul 10, 2014 05:25 PM
Pete in Maine
Dec 20, 2012 04:24 PM
gitane59
Jul 31, 2008 06:53 PM
sprinter5k
Jul 5, 2004 07:43 AM
