Sponsored by: Real Truck
ac compressor clutch??
Old Jun 14, 2004 | 12:01 AM
sprinter5k's Avatar
sprinter5k
Thumbs up ac compressor clutch??
I have a 99 sd with the v 10. A/C compressor pully is making a lot of noise, Does any one have any know if the clutch is an easy change??
Old Jun 14, 2004 | 12:44 AM
wvabeer's Avatar
wvabeer
your compressor may be locking up try to add a little oil in the system
Old Jun 14, 2004 | 07:26 AM
sprinter5k's Avatar
sprinter5k
thanks, but I pulled the belt off & the pulley spins but has slight amout of roughness & a little play from front to back. I'm sure th noise is in the pulley / clutch assembly, I'm not certain as to how hard the pulley/clutch is to change & whether or not it takes a special tool to remove the pully? thanks for the help.
Old Jun 15, 2004 | 07:48 AM
sprinter5k's Avatar
sprinter5k
update for any one intrested....it is a pretty easy fix, bearing in pulley was approx 1\2 gone. pulley is held on with snap ring & was not that difficult to change, just had to unbolt compressor to get additional room to get to the pulley.
Old Jul 4, 2004 | 07:41 AM
newfie4ever's Avatar
newfie4ever
Clutch Noisey
Did you change the Pulley or just the bearing. Mine is half gone also and I'm not sure if I can just replace the bearing.
Thanks
Old Jul 5, 2004 | 07:43 AM
sprinter5k's Avatar
sprinter5k
noisey compresser pulley.
Your soumd a whole lot like line as the seal was one & half of the ball bearings were gone. I changed the pulley....as it has the bearing already in it, I did not have to change the coil, hardest part was getting snap ring ( retainer ) off. I will say it helped to have had used a friend s lift as there is not alot of room to work with.
