VGT Readings
Old Oct 23, 2012 | 01:17 PM
mmenzies's Avatar
mmenzies
VGT Readings
What should i be expecting from my Scan Gauge redings for VGT
Idle
Normal cruising
hard Pushed accelerator
Mark
Old Oct 23, 2012 | 07:19 PM
04badford's Avatar
04badford
Mark, I'm learning the same gauge go to www.scangauge . net X gauge for ford that should help. benny tells us to test at koeo,park Idiol and park 2500rpm
Old Oct 24, 2012 | 11:26 AM
mmenzies's Avatar
mmenzies
anybody have any input for me on what the values should be.
Thanks in advance
Mark
Old Oct 24, 2012 | 11:42 AM
04badford's Avatar
04badford
Scrol down the posts I found that goosehunter had the operating values I didnt know haw to take those readings and link/post back, there under xgauge goosehunter hope this helps
Old Oct 24, 2012 | 12:00 PM
mmenzies's Avatar
mmenzies
sorry searched under goosehunter and came up with only 2 posts from him nothing relevant to xgauge or VGT values
Old Oct 24, 2012 | 06:50 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Values for VGT%
KO=0 LI=73 HI=43 OR=0-100 %
Here is a list of xgauges with values under most of them.
high idle is 2500 rpms in this. And the motor at operating tems. Check FICM also when cold.
https://www.ford-trucks.com/forums/1...l#post10227382
Old Oct 24, 2012 | 07:03 PM
04badford's Avatar
04badford
Mark, I brought the scangauge x gauge up on top of ur post . all else fails type in the search area scan gauge and it should bring all topics of scan II or go to 6.0power stroke and on the fist pages of 1 you will see ur post and then the scan gauge that I pulled up for you hopefully benny or bizmic or some of the othe guys will chime in to help ya out. Dont take my readings because I'm still learning this devise too. VGT at high 2500 rpm or operating value43 thru 100% is good, my truck verys at 85 low koeo=0 and high=43/44 but the true values are in that list
Old Oct 24, 2012 | 07:05 PM
04badford's Avatar
04badford
Thanks Sean, I didnt know how to post what you posted.
tcjhkbjt
May 16, 2015 09:53 PM
DanielT28
Sep 3, 2012 08:15 PM
DieselRunner
Jun 6, 2007 01:24 AM
F350SD
Jan 3, 2007 10:04 PM
Iceman31
Apr 4, 2006 04:52 AM
