hey guys what are most of you running on your drive-shafts greaseable or non-greaseable u joints. i finally figured out what size joints i need now i dont know whats better to use. i would thing the greaseable would be better but why are most of the non greaseable u joints more expensive..any input would be great
Sounds like common sense to me. Like bad joints; get the non ones.
that's what i figured, go with the greaseable joints but why would non greaseable joints be more expensive. to me that doesn't make sense. i always grease all my fittings every oil change. i know the stock u joints are non greaseable but i figure that's because ford wants to save a buck everywhere they can
Because people but things for lots of reasons. If Nike sold an inferior product they would still sell 10 times more than the same one with better quality from China. Also, lot's of people probably don't even pay attention to whether or not it has fittings, etc. Don't forget it costs more to add the fittings.
I think it's actually the other way around, non-greasable are higher quality and don't need to be greased to extend the life. Spicer joints are non-greasable and are widely considered to be the best unless you get into custom joints.
You can get spicer u joints in non greaseable or greaseable for the ford f250. The non greaseable come pre packed with a high quality synthetic grease according to there website. That's y they charge more for the non greaseable. I just got that info from someone from spicer after going on there website.
Thanks for all your input guys. I ended up going with moog greaseable u joints for my truck. Just ordered them from rockauto.com
Not all spicer U/J are non greasable.The only reason for non greasable joints is cost .Three less manufacturing operations-about 30 cents.
One thing with the ones you can grease is. If you have a high
load on the drive line and they are installed in the wrong
orientation they can split at the point where the joint was drilled
for the fitting. The other problem is sometimes the grease does not
make it to all points in the joint and you end up with a dry cap.
That then turns into rust and dust. Get the non=grease-able and
replace then every 100K or so.If you tow then you may want to
replace sooner but you can still avoid the stress failed joint that
you can have with the grease fittings. I have seen too many
go out the hard way.
